Do I need a servo programmer
Having read the numerous threads on servos in this excellent site, I have just purchased 6 Hitec 5945 servos for pattern use.
I have a JR 3810 radio do I also need a servo programmer?
Cheers
Phil
Cheers
Phil
The servo programmer is only really needed when you use more than one servo per control surface like two servos per aileron for a total of four. I assume that no pattern ship uses more than one servo per surface so you should be fine.
You will find it very helpfull if you use 1 servo on each aileron and a "Y" instead of ch 2 and 6 or if you use a servo per elevator half and a "Y".
