ZNLINE XIGRIS
Old 01-01-2013 | 04:30 PM
Default ZNLINE XIGRIS
Hi everyone
Can someone post a picture or two of their Chin Cowl attachment to the fusalage ........any locking mechanism available out their
I am having MEGA problems with attaching chin cowl on XIGRIS YS 175
Kind regards
MAVROS
Old 01-01-2013 | 08:55 PM
MTK
Default RE: ZNLINE XIGRIS
ORIGINAL: MAVROS
Hi everyone
Kind regards
MAVROS
MAVRE, is it the pump fit of the 175 that's not working? In close fitting front ends, I usually pin the rear of the cowl and bolt the front.
In my Derivative (Xigris fuse) thread I did the opposite (pinned front) since I use a gasoline engine with a rear intake/pump.
Old 01-01-2013 | 09:41 PM
Thanks for the reply but its not the pump the problem...
I remember seeing this spring mechanism on a pattern ship that held the chin cowl in place but I cant locate the sourse
regards
Mavros
Old 01-01-2013 | 11:56 PM
F3a Unlimited have them..
Old 01-02-2013 | 08:09 AM
MTK
ORIGINAL: MAVROS
regards
Mavros
Hmmm, a spring fast release set-up on a chin cowl will develop slop over time in a YS set-up. I wouldn't do it that way since slop in this area will makequite a bit of noise,in time. Nevertheless, if you're steadfast on using the spring fast release mechanism, MK used to sell them (checkwith Central Hobbies); most likely F3A U does as well.
Old 01-02-2013 | 08:32 AM
apereira's Avatar
Mavros,
I had the fast release on all my YS powered planes and never had any kind of problems, the Axiomes come with those standard, as Rune suggested F3A unlimited have a version and it is very good, larger than Oxai but very well made, just use guide pins on the back and the latches in the front, they can be about 6" from the front and will work great.
Hope it helps
Alejandro P.
Old 01-04-2013 | 02:31 AM
Jon Wold's Avatar
Mine is electric, and has just two MK snap plugs (Not the magic box kind) on the sides, and one wooden dowel guiding pin in front.
I don't have a detail photo, but you can see the location of the plug on the side here: http://www.flickr.com/photos/aerowold/5761709412/ (black dot)
Old 01-05-2013 | 11:27 PM
Thanks everyone for your advise .........its not what I had in mind but anyhow I think I solved the problem.
Two alluminium bolts on the sides and one at the front under the nose ring and carbon fiber pins at the back.This should be fail safe I hope....
Thanks again
rgds
MAVROS
