Power Unlimited longevity
Old 03-18-2013, 03:03 PM
Silent-AV8R
Silent-AV8R's Avatar
Default RE: Power Unlimited longevity
You want cooling inlet area?? I got you covered!! This is what the Abbra looks like. That is the OS 100-amp ESC sitting in front of the 2x4,400 5S packs. My packs are rarely over 110, even on warm days. The other photos are the outlets. Very effective. I call it the "Gaping Maw"
ID:	1863940   Click image for larger version
ID:	1863941   Click image for larger version
Old 03-18-2013, 03:36 PM
desertrider49
desertrider49's Avatar
Today's flights were in the 2650 range (intermediate, 6 minutes), I now remember doing the math and it was ok so I forgot about it.
Next question: I charge the night before and have developed a habit of topping off the batteries beforeI fly. Is this a good,bad or indifferent thing ?
Old 03-18-2013, 03:55 PM
Silent-AV8R
ORIGINAL: desertrider49
Next question: I charge the night before and have developed a habit of topping off the batteries before I fly. Is this a good, bad or indifferent thing ?
I charge the night before, sometimes a day or 2 before. Lipos hold charge very well, especially for that short of a time. I would not waste time "topping off". Especially just for practice.
Old 03-18-2013, 04:45 PM
rix
Is it recommendid to still dis-charge your batteries after a day of flying if you are not going to use them for while or is that day of use considered storage safe for a couple of weeks of non-use? This is assuming your within the 80% rule after the flights and so forth...
Rick
Old 03-18-2013, 06:11 PM
underdw
underdw's Avatar
Nice discussion!
I will focus more on battery cooling and temperature as the cause of my sometimes poor battery longevity.
Just ordered an onboard temp monitor that a buddy uses on the rear cylinder of his IMAC plane. This device records peak temps. May need to be "calibrated" against an IR temp gun, but if it's junk I'm not out too much $. I bought from this guy's ebay store for $10.
http://www.gonitrohobbies.com/Venom_..._06_p/0602.htm
Old 03-18-2013, 07:27 PM
  #31
VerneK
I top mine off at a 1-amp rate and have put in anywhere from 90 - 200mah. I wouldn't top off at your normal 1C rate.
Verne Koester
Old 03-18-2013, 07:34 PM
  #32
VerneK
If I fly a set of packs and don't plan to fly again for a few days, I just leave them in that state (20% or more still in packs). If it's going to be a long term storage, I charge them up to storage levels. If I have any packs left that were charged but not flown and don't plan to fly for a week or so, I discharge to storage levels. Of course, weather can impact the best of plans, but that's my normal routine. I usually charge the night before I'm going to fly at 1C and then top off the packs right before I fly at 1 amp.
Verne Koester
ORIGINAL: rix
Rick
Old 03-22-2013, 06:57 AM
  #33
g_mkoch
anyone know when PU packs are going to be back in stock?
Old 03-22-2013, 02:03 PM
  #34
pvogel
pvogel's Avatar
F3AU site says 3/29, but it used to say 3/18 - I assume there was some shipping/customs delay.
Peter+
Old 03-22-2013, 02:36 PM
  #35
Chris Moon
My Feedback: (8)
Chris Moon's Avatar
Several delays at the factory as we don't use off the shelf cells for the packs so they have to make a special run for our cells. They were due back in early Feb but it has been pushed back and should arrive within the next 10 days. We try to time arrival of fresh batteries for Spring and this time they are a little late unfortunately.
Old 04-01-2013, 01:28 PM
  #36
Scott Smith
Scott Smith's Avatar
Any updates on the X 35C 5S-5100s? (I'd hate to think the web page is still showing no stock due to a cached page on my machine!)
Old 04-02-2013, 06:08 AM
  #37
Zeeb
My Feedback: (41)
Zeeb's Avatar
ORIGINAL: Scott Smith
I'd be curious as well since the webpage is still showing out of stock, arriving on March 29 and I'm waiting on four of 'em....
