Building motor mount box on Monolog 70
I've been reading both the manual (pictures with simple captions) and trim instructions (very very bad translation from Korean or Chinese to English) for the Monolog 70.
The trim instructions say to build 1.5* of up thrust with wire gear and 0* up thrust with composite gear. Doesn't mention side thrust.
The manual says 2* or 3* of right thrust depending on motor and doesn't mentioned up/down.
I'm trying to decide how to build the box. I'll probably keep the crappy composite gear it came with (with slight modifications) or maybe upgrade to better carbon gear.
I could just build the box square and then trim with spacers as needed depend on how it flies.
Or I could start by building the box with 2* right and then trim as needed.
Thoughts?
Thoughts?
-l2t
I dry-fit the motor box on my 70 last night. The laser-cut parts key together really well. It looks like the side and up thrust are built in so I'm not going to modify it in any way. I'll leave it like as built. If after flying it needs trim I'll shim it but I suspect from what I've heard about the design, it should be pretty good as built.
-Ken aka l2t
-Ken aka l2t
