Futaba High and Low speed rx
Hi
I have one off this that I was think about using in a funfighter..but the servoes is analog and therefor will not work in HS ...can someone give me a step by step how to get it in LS????? I kown this is not the radio forum ..but thought someone had done it!
http://www.gpdealera.com/cgi-bin/wga...pgm?I=FUTL7639
You need to press and hold the link button Before you turn power on to the Rx, turn power on (while holding link button down) and release the link button after power is on, and that should toggle between normal and FASST mode.
Turning power on to the Rx and then pressing the link button (for a couple seconds) will force the Rx to find a Tx link.
