Futaba 12FG again
Old 08-19-2015 | 11:44 AM
My Feedback: (9)
Default Futaba 12FG again
Ok im trying to correct a small pull to the canopy on knife edge, and using the rud to ele function on the 12FG, my questions is how do I get it to come in with say a very small amount of stick movement 4 points slow rolls etc. The manual tells you how to set it up but not to adjust to the stick movement, just say see back of the manual for curve setting.
Old 08-19-2015 | 06:39 PM
woodie's Avatar
jetmech42
I use the 'point curve' function which allows you to adjust how much movement you get with the slave (elev) function for knife edge. The 'point curve' allows you to set the curve shape at multiple points along the deflection. You can set up how much deflection you want for elevator for each point along the curve. I typically have a small amount of elevator deflection near center but do not increase that deflection as the rudder throw increases.
Woodie
