Setting Up servos
Old 05-22-2016 | 08:02 AM
OhD
Default Setting Up servos
The other day I was praising the features of programmable servos and mentioned the ability to set the neutrals to exactly 1.5 msec. I've been flying a Jeti RC system and its default neutrals are 1.5 (sub trim, trim, etc. are all at zero) whereas Futaba's were always some odd number like 1.52. Tony Frackowiak mentioned that a few of the JR servos have adjustable neutrals. First power up the servo with the desired neutral pulse width and put the servo arm as close as possible to where you want it. Then with the screw from the servo arm removed, insert a small flat blade screw driver in the hole and rotate it until the servo arm is exactly square with the servo body. Tony mentioned the 9411 and 3711 servos and I was able to adjust my 3421 elevator servos.
I'm in my ninth decade and still learning.
Jim O
Old 05-22-2016 | 08:23 PM
drac1's Avatar
That is interesting, I didn't know that either. I just looked at my 9411 and yes, there is a screw driver slot in there.
So it's basically a mechanical sub trim?
Old 05-23-2016 | 06:40 AM
OhD
Yes. And that is a good thing, as it is good to minimize the subtrim in the transmitter. But that is another story.
Jim
Old 05-23-2016 | 11:20 AM
My Feedback: (46)
All these JR servos have it: 9411, 3421, 3517, NX3421, and NX3425
Old 05-23-2016 | 12:41 PM
apereira's Avatar
WOW, really learn a new thing everyday, I did not know that!
Thanks for sharing, I will check my JR servos.
Regards
Old 05-24-2016 | 04:09 PM
kenh3497's Avatar
Nothing new here. Does anybody remember the servos with the square output shaft? They all had a screwdriver slot to adjust the pot so the arm could be centered or offset slightly to provide differential.
Ken
Old 05-24-2016 | 07:34 PM
Yeah, Ken ...
But that was back when we had to bang the rocks together!
Regards,
Dean Pappas
Old 05-27-2016 | 06:00 PM
kenh3497's Avatar
Originally Posted by Dean Pappas
Yeah, Ken ...
Regards,
Dean Pappas
Oh so true! It seems I'm still banging rocks.... At least it feels like it!
Ken
