Como (ST) 75 for pattern
TX
I just tached my Como 75 with a mac's muffled tuned pipe spinning a 12x12 APC prop at 10,400 using 10% Rich's Brew and a Thunderbolt plug with idle bar. Does that sound about right? How much thrust does that come out to? Thanks guys and hope all of you have a wonderful weekend.
In Christ,
Joel Chavez
In Christ,
Joel Chavez
Joel:Hello again!, i think that are very good numbers, considering that the OS .61 HANNO SEPCIAL used to work between 10500 and 11000 with the APC 12X12, now try 11X10 and 11X11 that can work too.
SALUDOS
Ernesto Delgado
TX
My LHS doesn't have those props available. I'll have to "hunt" down those props and see what happens. I was very inpressed with the numbers too. I need to tune the pipe though since I simply bolted it on and away we went. Thanks for insight Neto and I'll see if I can find the props you mentioned down in the Valley this weekend. Hope you have a great weekend.
In Christ,
Joel Chavez
In Christ,
Joel Chavez
