Nylon Gearset for JR8411
Old 12-14-2003 | 01:57 PM
Malcolm H's Avatar
Default Nylon Gearset for JR8411
Can somebody tell me the JR part no. for the gearset to convert 8411 to 8411SA?
There are two sets of gears in the packet and I have done this conversion on a couple of servos but have lost the empty packet!
Malcolm
Old 12-14-2003 | 02:49 PM
Default RE: Nylon Gearset for JR8411
The Part number is:
JRPS8411SAC
http://horizon.hobbyshopnow.com/prod...od=JRPS8411SAC
TN
Old 12-14-2003 | 02:53 PM
ofremmi's Avatar
I have converted a lot of 8411's to nylon gears, the JR partno. to use are : 8101. It's a ser of gears that fits into a whole range of servo's : 811, 8201, 8301, 8401, 8300 etc. For a picture of the JR-package with the gearset : http://home.online.no/~ofremmi/F3A/T...tuffForF3A.htm
Best luck
Ola Fremming
Old 12-14-2003 | 03:31 PM
patrnflyr's Avatar
My Feedback: (7)
I bought the SA conversions for my 8411's that are used in my Angel's Shadow. They are alot better in the slop department with very little if any. By buying the conversions, they also give you the faceplates to put on the top so you won't confuse the 8411SA's with anything after the conversion. I also think you get 2 conversion set per package. I may be wrong about this though. John, Lubbock, TX
Old 12-14-2003 | 07:48 PM
My Feedback: (16)
Why not do what Futaba does and just change the number 2 or middle gear. leave the other metal gears in. With the plastic #2 gear, the metal gear will not wear.
Old 12-15-2003 | 03:48 AM
Malcolm H's Avatar
Thanks for the info guys.
Malcolm
Old 12-15-2003 | 02:20 PM
When replacing them you will have to leave the metal oputput gear in.
You can also get them from Central Hobbies.
WG
Old 12-15-2003 | 07:05 PM
Bob Pastorello's Avatar
My Feedback: (198)
I have 4 8411's that I converted to nylon gears, *including* the nylon output gear. The package (same as Ola referred to) is a multi-purpose gear set...my bag is marked for the 8101, adn is the p/n for the 8231! Imagine! Interchangeability!!
The nylon output gear is a bit of a chore to replace with the little insert that indexes the pot wiper pin; then the bearings aren't all that easy....but they work, and become slop-free, psuedo-8411SA's.
In case anyone is curious - I did what I did based on Danny from Horizon's (JR service) recommendation. Works just fine.
