flair swallow help
flair swallow help
i just bought a swallow and at the min it has a fixed u/c but i noticed today that there is a place to put retracts all ready in. can any of you guys help me by telling me what kind of retracts i need or what size as i am new to the retract side of things. its a 90 size flair swallow
cheers
cheers
RE: flair swallow help
I have a lark one one size smaller than yours. i would keep with the FIXED u/c as i have been tol if you have the retracts you have to 'beef' the surrounding area up so it does not break on a heavy landing.
trust me with the fixed u/c and the spats over the wheels it looks great in the air!
Adam
Adam
hi justin
yeah i flew her on sunday fantastic mate engine was a bit coughing and farting but that soon stoped dont know if it hasnt been run for a while but its ok now. cheers for the pan bud
speed_freak1
thanks for your reply i will keep that in mind but would still like to try em out i now have the retract and are fitted but another problem cant find servo hole [:@] lol but like you said i will keep u/c on for the time being
have a good christmas all
derek
derek
im not sure about the servo hole.. i will have a quick look at mine later and see if i can spot an obvious place.... it has to be sitting there right in front of you (as they always do!)
Good luck with every thing.
Have a great christmas yourself and enjoy the new year.
PS: (what surface are you using as runway???) (tarmac or grass ?)
Grass will rip the retracts out pretty fast while concrete will take a little longer
Derek,
I have dug out the instructions and it show's the retract servo position in the left wing panel(top!) next to the wing joint. The box is 66mm long and 46mm wide. I dosn't say how far the box is from the LE but look about 35/40mm on photo. I will post the instruction to you now I have found them.
Justin
Justin
Also check you will have enough ground clearance before you commit to the retracts. You might find you struggle to swing anything bigger than a 14/15" prop as the leg length is pre determined buy the well size. Just a thought.
