Widebody CG location
My Feedback: (8)
I'm finishing the set up my Widebody. The "instructions" say 30 - 35% and up to 40% for 3D. I can calculate either that as % of cord or as % of MAC, but where are most guys setting their cg? Like in inches from leading edge at the root?
ORIGINAL: ual767
I got the info from Marcelo in an email. It's 130mm from trailing edge (5.118 inches). Thanks Marcelo.
From Trailing edge? that seems way to back to me. I will check mine today to let you know.
Saludos
The CG in mine is at 15 cm behind the leading edge at the fuse side. That is 40% of the wing chord at the root.
The wing is tapered at both the leading and trailing edge so I find it unnecessary to calculate the MAC.
Hope this helps.
Hope this helps.
