Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 CA Models Eclipse: wing incidence adjusters >
Old 08-07-2004 | 10:33 AM
Neo02's Avatar
Default CA Models Eclipse: wing incidence adjusters
Hello to everybody,
I'm at a loss here: My Eclipse had 2 sets of stab incidence adjusters but none for the wing. As I understand it (and as I did it in the past), I need 4 adjusters in the fuselage to be able to rotate it around the wing tube, and in the past I had the wing incidence adjusters from Gator R/C. Now I don't know if I should wait for the Gator accessories or install the additional stab incidence adjuster that came with the kit -- is it enough for a 2M wing??
Any pics of your installation would also be helpful!!
Thanks a lot to anyone replying
Regards,
-Fabrizio Albonico
To swk550: your pics already helped a lot! Thank you for your [link=http://www.rcuniverse.com/forum/CA_Model_Eclipse_building_tips/m_1503184/tm.htm]thread[/link].
Old 08-07-2004 | 05:52 PM
Chris Moon's Avatar
My Feedback: (8)
Default RE: CA Models Eclipse: wing incidence adjusters
The Eclipse should have come w/ 1 pair of Gator wing adjustors. They show it set up using 1 per wing half, and a wing bolt in the front as the other anti-rotation device. I bought a full set for my Eclipse, and used 2 per side as in the Gator instructions. The extra stab adjustors must have been a mistake. When you are finished, you will really like this airplane.
Old 08-08-2004 | 03:30 AM
Neo02's Avatar
Hi Ual,
my kit must have contained one stab set too many.
Not too bad, though, because I can use the extra set in another plane.
Thanks for the clarification!
Regards,
-Fabrizio
