MVVS for pattern
My Feedback: (55)
I had a MVVS .77 in an Illusion pattern ship and a MVVS .90 in a Widebody 60.
Both engines produce a tremendous amount of power. The older versions had
carburetors that were very sensitive and hard to keep adjusted. There are
updated replacement carburetors available that solve that problem and the new MVVS
engines come with the new carbs on them. Strong running engines that have a lot of low
end power , pull big props , runs on 0 to 5% nitro so are economical to run. A handy
feature is they can be configured for side or rear exhaust. Great engines.
tommy s
tommy s
Thanks.
What engine should I use- .91, .77 or .61 (all with tune pipe)?
The plane specification:
Wing Span : 67.0 in / 1700 mm
Wing Area : 789 sq in / 50.9 sq dm
Flying Weight : 8.0 lbs / 3600 g
Fuselage Length : 67.0 in / 1700 mm
Engine Required : 2C 0.61 cu in
4C 0.91 cu in
Radio Required : 5 channels, 6 servos
4C 0.91 cu in
My Feedback: (7)
I have a MVVS 90 on a very heavy (10lbs) bridi XLT and it was impressive how it hauled that beast around. It's setup R/E with MVVS header and pipe. I'm cleaning out the shop for winter project so I'll make you a deal on the engine,header and pipe if anyone is interested. Has about 3 gallons on 15% Powermaster ran thru it. Nice and broke -in.
Mike A. [8D]
Mike A. [8D]
