Swallow EX90
Old 01-03-2005 | 08:55 PM
Default Swallow EX90
Could use some advise on set up for a Swallow. I'm just getting into
pattern and would like to set this plane up as best I can. I will be using
a ST90 on it. Any advise on control rod set up as opposed to the stock
rod? Control horns? Pull-pull? All advice and suggestions appreciated.
Jerry
Old 01-03-2005 | 10:36 PM
hankpajari's Avatar
Default RE: Swallow EX90
Do a search on Swallow, try here and Google. You will come up with several good threads and reviews. I did and they help a lot. Will be using an OS 120FSIII pump on mine.
Old 03-23-2005 | 04:48 AM
I've recently bought a Ex90 Swallow as project for my son. I am completely new to RC Planes and i need help on choosing which Engine and Remote i will need - All help will be most appreciated
Old 03-23-2005 | 07:40 AM
bear in mind that a lot of what was said a year or so ago was about the original swallow, not the swallow ex. The EX is a better constructed plane in my opinion. Still, points such as reinforcing the wing seat doubler are still good advice. It as a good flying model and an ideal first pattern plane.
James
