tai ji 60 C.G?
Old 02-09-2005 | 10:06 AM
Default tai ji 60 C.G?
Hi:
Could everybody help with de Correct CG taiji 60 ?
My plane flies unstable. Alway i have to correct aleron stick.[:@]
Thank´s
Old 02-09-2005 | 12:45 PM
Default RE: tai ji 60 C.G?
Hi
The manual claim Quote: The ideal CG position is 150mm (5.91 in) behind the leading edge measured at where the wing meet the fuselage.
You can download the manual here: http://www.theworldmodels.com/para/i...nstruction.pdf
Old 02-10-2005 | 10:59 AM
Hi,
My manual calls for CG at 150 mm (5.91 inches) from leading edge. I flew mine with CG at 7.5 inches from leading edge and it was not
tail heavy.
I used YS 91 FZ with tank at CG, battery behind wing trailing edge and several ounces of lead inside fuselage at the tail post.
The manual calls for ailerons to have only 16.8 mm up and 16.8 mm down travel--total of 33.6 mm travel. That is a good place to start.
Hope this helps.
Old 02-11-2005 | 09:58 AM
Thank´s for yours information.
I´ll test my plane and i´ll tell you what´s hapens...
