2 M pattern plane what Futabe servos
![](/forum/images/badges/premium_member.png)
Hi
Looking for advice. I am about to start putting my Synergy together and I have looked at the Futaba website but I am unsure what servos to go for.
Does anyone have any recommendations. I am going digital for the holding power and the fact that the Synergy has BIG surfaces.
Mike
Mike
![](/forum/images/badges/trading_plus_member.png)
Hi Mike,
This will go into my E - Synergy...
S9154 on ailerons
S9650's on elevator
S9151 on rudder
In case of using the MK dual elevator coupler or DEPS system on the elevator I would recommend the S9252.
S9154 on ailerons
S9650's on elevator
S9151 on rudder
I am running almost the same servos as Morten except on rudder:
S9154 on ailerons
S9650 on elevator halves
S9451 on rudder
I use a 5.7 V regulator which is safe for S9154. Others (S9650 and S9451) are ok with a 5-cell pack.
S9451 with 5.7V is almost as strong as S9151 with 4.8 V. I find this enough. OTOH S9451 is a lot faster and actually as fast as other servos in my setup making it a nice balanced combination. The speed is an advantage and you can see a difference in snaps, stall turns and spin entries.
ini
S9154 on ailerons
S9451 on rudder
ini
