Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 URGENT: MK soft mount problem. NATS in 2 days >
Old 05-16-2005 | 10:38 PM
pmr
Default URGENT: MK soft mount problem. NATS in 2 days
Having problems with my MK soft mount for YS110. After only 4 flights the rubbers on the mounts were all mushy and two of them were cut in half. Can anybody suggest to me what kind of rubber I will use for replacing the original ones. I only have 2 days til the start of our NATS here in our country (first time to join and only sportsman). Hope to hear your recommendations.
Old 05-17-2005 | 06:19 PM
Bob Pastorello's Avatar
My Feedback: (198)
Default RE: URGENT: MK soft mount problem. NATS in 2 days
Get the "HIGH Isolation" rubbers. Much firmer, will not cut through.
ALthough MY experience has been that they were FAR too hard.
Old 05-18-2005 | 04:19 PM
... hmm, mine MK mount with YS 140 broke the rubbers all the time .. i tried some reinforced ones,but the vibration level ended up so hard that you could hardly read the letters on the craft...
Ended up with a hyde mount ...
Kjell Olav
Old 05-18-2005 | 05:25 PM
My Feedback: (198)
Me, too. Put in the Hyde mount last weekend. WAY better than the MK.
Old 05-22-2005 | 06:09 AM
ab1
Generally the rubber is cut where the alloy mount ends. If this is the case with your mount, gently round the ends of the alloy that touch the rubber. By removing this sharp edge, your rubbers should last much longer.
Old 05-23-2005 | 08:26 AM
Hi All,
I am in the process of putting together the CMPro Leo 110. Is this MK Soft Mount the one that ships with this plane and should Ibe cautious of using the mount consisting of 4 rubbers with my OS 91 FX?
Regards
Danie
