What is you'r 2 meters setup?
Old 09-28-2005, 02:06 AM
ram_z's Avatar
Default What is you'r 2 meters setup?
Hi everybody what's up?
I'm looking forword to get my new model (BN MODELS IMPULSE).
Well, I was started to search servo's to the model and I wanted to ask you guys what is you'r setup?
which servo's do you use?
what battery?
I'm using JR TX&Rx and I wish to use JR servo's also.
thanks in advance
Ram_Z
Old 09-28-2005, 06:56 AM
Default RE: What is you'r 2 meters setup?
9411SA - ailerons
8311 - rudder and elevator
368(replaced metal gears with nylon) - throttle
Li-Ion battery w/ voltage regulator
Old 09-28-2005, 08:38 AM
My Feedback: (92)
8411SA's on ailerons.
3421SA's on elevators
8611A on rudder
TP 900-mah 2S for R/C battery
No throttle, I'm using Hacker power.
Old 09-28-2005, 04:28 PM
Adamg-RCU's Avatar
Tony, have you tried the 9411SA on ailerons?
Old 09-28-2005, 05:19 PM
My Feedback: (46)
Adam,
I have two planes with over 230 flights on each airframe with these servos running Webra 1.60s. I stand corrected though on the servos. I replaced the metal gears with nylon gears in 9411's, essentially giving you 9411SA's.
Old 09-28-2005, 05:58 PM
My Feedback: (92)
Adam,
Yes I have. I prefer the 8411SA's. They seem better in turbulence and in snaps.
Old 09-28-2005, 06:32 PM
Scott Smith's Avatar
Ailerons - FUT S9550
Elevator - Hitec 5925MG
Rudder - JR 8411SA
Throttle - Hitec 475BB
No brand loyalty here! Metal gear servos holding up just fine with over 250 flights (centering checked with Budd laser meter.)
Power is provided by a NMP 2000 LiIon with a Jaccio 5.7v Perfect Switch.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
