OS 140 RX questions
Old 03-01-2006 | 11:50 AM
Default RE: OS 140 RX questions
If you go to Ed Hartley's page, you can see a lot of different OS1.40 set ups. http://www.rcpattern.com/2cycle.htm
I used a pipe for a while, but the last two planes I have used a Bolly 590 muffler. No set up or tuning with a muffler. Mine turns a 15,5X12 4 blade at over 7,800 rpm on 15% fuel. Plenty good for most 2M's. I'm half convinced that by the time you make a tuned pipe long enough not to have a noticeable"peak" that you lose much of the benefit of a tuned pipe.
Old 03-03-2006 | 11:18 AM
Great info guys,
I too own a 140RX that is still in the box, the plane is not ready yet.
Any tip or procedure for tuning the correct distance of the pipe?
Old 03-03-2006 | 04:59 PM
My Feedback: (121)
Good point, Jeff. Also, it helps remove the midrange 'burble' (richness).
Me, I shorten the pipe, fly the whole flight at full throttle and can fly the FAI P05 sequence in 5 minutes - kidding!!
And the muffler is a lot shorter!!
-Will
