TS Composite Oxalys
Old 09-23-2006 | 02:44 AM
Default TS Composite Oxalys
Hi
I have more or less decided that my next F3A plane will be an Oxalys. My building time is limited so I´m very interested in the ARF TC Composite Oxalys. I have seen it at a Swedish dealer, it looks ok even thou the wing seems to be 100 - 150 gram heavy (as stated in this forum before). It should be very interesting to hear from some of you that have flying experiences with the TS Composite Oxalys (and of course very interesting if anyone have tried both the TS Composite and the ZN-line). What weight have you ended up with? I intend to use an YS 160.
Thanks in advance
Alf Engqvist
Sweden
Old 09-23-2006 | 05:16 AM
Default RE: TS Composite Oxalys
I¨NEED TO KNOW CG FOR OXALIS TS, CAN YOU HELP ME?
GRAUPNER 8411 IS GOOD SERVO FOR THIS AIRPLANE?
THANKS!
Old 09-23-2006 | 07:16 AM
papaone's Avatar
Hello
CG 32 % is at 170 mm from the leading edge in the chord middle of the wing.
You can verifie with this logiciel to download.
http://www.jean-claude.etiemble.com/cm/indexE.html
Old 09-24-2006 | 09:24 PM
Has anyone actually flown the plane? How does it hold up to the vibration of a YS160? We all those Impacts were breaking apart but the Astral XXs are holding up real well even after a couple hundred flights. How does the TS Oxalys fly? Saw a ZN Line version in Japan at the CAOCC. I liked how the plane looked but found the T cannilizer really ugly but that's just me.
Jayjay
Old 09-25-2006 | 07:10 AM
thank you papaone.
Old 09-26-2006 | 05:46 PM
Leoni,
I bought my OXALYS from F3aLorenz in Germany
initially the manual says 165mm but
received an email from W. Lorenz NOT TO USE 165 mm but 220 mm instead.
Hope this helps
Old 09-27-2006 | 05:40 AM
THANK YOU JOAQUIN!!
I DON´T KNOW WERE IS THA EXACTLY POINT FROM COLOCATION ESTABILIZER.
I´M FIND TWO VERSIONS, CAN YOU THELL ME WHAT IS THE RIGHT VERSION?
tHANK`S FOR ALL.
Old 09-27-2006 | 05:43 AM
My Feedback: (27)
245-265mm from trailing edge for CG
