FUEL FROM JUG TO PLANE
Old 10-11-2006 | 08:38 AM
Default RE: FUEL FROM JUG TO PLANE
ORIGINAL: woodie
ORIGINAL: AAM1024
I have a 5 year old MK hand pump. I was having trouble with engines and fuel pumps years ago. I switched fuels to Cool Power and both problems went away.
I could get about 3 months on a fuel pump using Magnum Fuels and the pump would leak and sometimes even lock up. I switched to Cool Power and the same pumps that would leak and malfunction have now been good. The MK hand pump is excellent. What fuel are you using?
Allen
That's interesting, when I fly glo, Magnum is all I use. Same MK hand pump you are using, 4 years of pumping Magnum 15% and #1 thru it and still going strong. Wonder what is different?
Woodie
I thought all your leaky fuel pump problems went away when you changed over to that new fuel pump, Astroflight?
Old 10-11-2006 | 10:53 AM
woodie's Avatar
ORIGINAL: Derek.Koopowitz
ORIGINAL: woodie
ORIGINAL: AAM1024
Allen
Woodie
Well, it's kinda hard to tell when it leaks, the electrons don't leave much of a trail with a small leak. However, with a 'big' leak ( zap, spark, snap, crackle) the leak is much more obvious.... ;-))
Woodie
Old 10-11-2006 | 01:23 PM
I have used my hand crank tower hobbies pump for years with no leakes and no problems. Now I supose next time at the field it will start leaking.
Old 10-11-2006 | 03:48 PM
Don M.'s Avatar
David me son. What's wrong with one of these. I have one for glow and one for gas. Both are over 10 years old. 1.5 ozs. per squeeze, in or out. You've seen me use mine, Errol has them...... Cheers
Here's the Link.
http://www.businessvision.net/Edge/M...y&PageNumber=1
[img][/img]
Old 10-11-2006 | 04:25 PM
Don: I used them way back when. Found them slow and they don't fit in my field box.
Also,I checked the DuBro site a few weeks ago,and couldn't find them so assumed they were not available. Neither I or The Beav have seen them at Aerial's shop lately. The Six Shooter will do for the rest of this season.
Cheers,and keep warm,,,,,,,,,,,,,,,,,,,,,,,,,,Dave
Old 10-11-2006 | 04:42 PM
  #31
Don M.'s Avatar
SLOW !! Your Six Shooter takes 94 turns and I can fill a 20 oz. tank from empty in 15 squeezes max. That's a lot of work - your not getting any younger
Of course if they are not available then what's the use. I could rent you mine until I get home next summer.
Old 10-11-2006 | 04:53 PM
  #32
My Six Shooter only requires 87 turns!
And I do have one of those Dubro fuelers. I have used it for gassing my Texan's G-62 since 14 years ago. Minus this year when it sat idle.
