KIT, ARE THERE ANY GOOD KITS?
Old 11-19-2006 | 11:12 AM
Default KIT, ARE THERE ANY GOOD KITS?
Hi there First of i would like thank you for taking time to read this and i would like to hear your opnioin about a stupid question ,
Im looking for plane #3 I want it to be a pattern ship and for it track like its on rails were if i put it a a 45 i want it to stay there.... My dad wants to build a kit so may aswelll kill 2 birds (no pun intended) with one rock. It will be our first kit so it needs to be resonibly easy to build.
I am in no way planning on putting a YS in this thing maybe an OS or a SAITO i dont have the motor so i dont have to build around a certain size but i would like it to be about 60 or so inch wingspan prefarably a tail dragger. I will soon be getting a computerized radio so number of servos is a non issue
please suggest.
Thank you, Steven
Old 11-19-2006 | 11:29 AM
RC_Pattern_Flyer's Avatar
Default RE: KIT, ARE THERE ANY GOOD KITS?
CA Models widebody 60.. hands down.
available from Aeroworks
Chuck
Old 11-19-2006 | 03:21 PM
Thank you Chuck
Old 11-22-2006 | 06:41 PM
any other ideas? Im not use to getting such a low imput from you guys on RCU some of you must have built a kit any good ones?
Old 11-22-2006 | 06:45 PM
MHester's Avatar
In that size range, the Widebody 60 or Epsilon is about it.
Realize if you go that route that both of them are "pattern/3D" planes, so you may want to down size the aileron length. The one I built I started the aileron cut outs at about 4 inches from the fuselage instead of right up against it.
-Mike
Old 11-22-2006 | 08:18 PM
MHester : have you flown the epsilon you shortened its airlerons?
i havent started building mine, and im planning to use it only for pattern
how was the result?
thanks!!!
Old 11-22-2006 | 08:28 PM
MHester's Avatar
Never had an Epsilon, but had a Widebody.
That's the one I shortened the ailerons on, and it was a very good pattern plane. It's only drawback was it's size. It flew like a modern 2 meter at the time until the wind kicked up, and then you could really feel how small the plane was in comparison.
But it flew great!
-Mike
Old 11-22-2006 | 10:09 PM
BJM
I built and and now am flying an Epsilon. I agree with Mike - it flys great - but its still not a 2 meter pattern plane.
Billy
Old 11-24-2006 | 11:10 AM
Ok you have my enterst in the wide body .60
http://www.aero-works.net/store/detail.aspx?ID=237
the engine is 4 stroke better then 2 stroke for this application what size do i go for what they say oor over power the hell out of it? Servos. what kind of servos should i put in this thing are there some that are more important then others (if i were to not have the money for digital servos allround what can run with an anaolog servos without impacting flight tooo much) im a patrtern nood i know nothign so please inform me
Thank you
Steven
Old 11-24-2006 | 11:33 AM
MHester's Avatar
Engine: If you want a 2 stroke, the OS 120 is most likely the best bet. If you want a 4 stroke, a YS 110 is the way to go. It's personal preference, 2 or 4 stroke. If you're a beginner practicing you need reliability over performance edge. Therefore I'd have to say the OS because the YS will cause a lot of vibration. This is ok if you're used to it, but just realize it equals more maintenance on the airframe over the long run.
Servos: all you can afford. If you want a clean and true flying pattern plane, use servos with good centering and about 80+ inch/ozs of torque for everything except the rudder. use at least 150+ in ozs there.
I won't recommend exact servos, just look around. Don't skimp, or you'll hate life. Just my 2 cents worth.
-Mike
Old 11-24-2006 | 04:36 PM
I assume the servos should be digitals
Well the os 120 give me unlimitted vertical?
Old 11-24-2006 | 04:50 PM
MHester's Avatar
ORIGINAL: Flying freak
On the 60-90 size, yeah, you better believe it!!!!! You'll have all the vertical you can stand.
Digitals are best, but a really good quality coreless would be ok too.
-Mike
Old 11-24-2006 | 04:53 PM
ok cool cause im a gerneral rc newb i ahve a supersportster coming in this week and that will be my second plane my 3 will be this pattern and i really dont know much about servos and motors and things like that
Old 11-24-2006 | 09:07 PM
Stupid question how many servos will i need it says 4 ch on there webite but i think they mean a 4 channel with 5 servos y harnss or is it actually 4 servos?
if so its not tooo bad i mean go for those nice 80+ inch/oz il need only of them (ail/elev) and one of the heazy duty for rudder (im cheaping out on trotal sorry but this one will be a normal standered servos)
Old 11-24-2006 | 10:37 PM
flyintexan's Avatar
You are right, they mean 5 servos....one for each aileron. You may want to plug each aileron servo into a seperate channel and forget the y-harness. This method has its advantages.
Old 11-25-2006 | 07:37 AM
Well i am planning on giving each servos its own channel if i do go forward with this project this allows me to electronicl adjust things
I also noticed it is a "split" elvator do i also need 2 servos for the elevator?
Old 11-25-2006 | 08:26 AM
flyintexan's Avatar
For the elevator you can use what is called a "DEPS"....dual elevator pushrod system. There is a nice DEPS package available from centralhobbies.com that comes with everything you need. Troy Newman has some great notes/articles on installing the DEPS properly as well, which I think are somewhere on Central's website. If you use the search function here on RCU you will find lots of threads with references and pictures of DEPS installations.
Good luck,
mark
Old 11-28-2006 | 07:07 AM
Thank you for everyones help
