New Model
CA
ORIGINAL: rgreen24
Browsing and found this new bird.. Looks like the big brother to the Astral XX
http://www.vit.or.jp/~tomo/kakuta/altair/altair.html
Adrian
CA
ORIGINAL: Angus Balfour
Simply stunning. Looks like two servos in the tail for elev Adrian?
A
A
Adrian
CA
ORIGINAL: ericng
The Aurea, another new pattern from Mr. Naruke, is a modification of Astral XX with fat fuselage and thicker wing. Heard that it is designed for the P-07.
According to Alex Lau, the X-treme Astral XX is exactly the same as Naruke Hobby's XX Plus. The Aurea - which has been in the market for about a year now, also has the same dimension as the XX Plus - and its manufactured by X-treme as well. The only difference is it doesn't has a seam on the fuse, and its only for Japanese market only.
Adrian
The information came from my friend Mr. Ikegami, the editor of Gami Report, that the Aurea has size difference against Astral XX, more drag but fly relatively smooth, construction seam not mentioned.
CA
ORIGINAL: ericng
You're right, Eric. It is different than the XX, because the Plus is slightly bigger than the first XX.
Adrian
