ZNLine factory: Enigma Building
#376
Mark,
Nice work
Question: Why do you install the servo tray last? I thought it would be easier to fitout during the building phase and simply re-install all your hard work when the model is finished (minimise hangerd rash)
Peter
Nice work
Peter
#377
Moderator
My Feedback: (58)
Re: Thank you Peter.
Originally posted by MarkNovack
The 9550 and 9350 are absolutely not necessary. No, no, no.
There is a difference. A good and positive difference, but those are very expensive servos. If money is not a big deal, go for it. If saving some money is in order, then the following are fantastic. A little bit slower in response but I think the difference should be invisible in real life...we simply do not ask our servos to move as quickly as they are capable of in most situations.
For digitals, the 9150s (low profile ailerons) and 9151s for elevator and rudder are fantastic and easier on the wallet than the latest ultrafast metal geared servos.
Mark
Mark
1) Are you running 4.8V or 6V ? Any voltage regulators used ?
2) Do you use dual battery packs or dual receivers for redundancy ?
Thanks...............Mike
#378
Voltage
We use 6.0volts with the 9150 and 9151 with no problems whatsoever. We asked our Japanese friends and they do them same. We all sort of ingnore Futaba on this one.
With the newer servos, Futaba makes no recommendations against running them on 6.0.
One battery pack, one switch. We have been using Ni-Cads. JP used Duralite for a bit but they all went South over the winter and we became a little paranoid about them. Perhaps we will give the Duralite Plus batteries a try someday. We are still around 9.4-9.5 pounds...not bad. The Ni-Cads sure are cheap, easy, and very reliable. I just changed a five year old battery in my Majestic and I did not have to nurse it carefully.
Why mount the tray last? I don't know. Tradtion? Little in here is set in stone. Not having the tray mounted does prevent any possibility of overspray hitting the beautiful CF finish, but the inside of the airplane is masked off very carefully anyway. As far as hangar rash, we are pretty careful with these airplanes. After 1000 flights you probably will not see any hangar rash. Just grass whip on the covering and the occasional FOD damage.
Mark
Mark
#379
Moderator
My Feedback: (58)
Re: Voltage
Mark
Mark
Also, what is the capacity (mAh) of your NiCd battery ?
Thanks.........
#380
I missed the question, sorry.
No voltage regulator. The digital servos show zero twitchyness fresh off of the charger. Perhaps PCM adds something to the equation.
The batteries are Sanyo 1150mah (I do not know the cell type) but they normally cycle out to almost 1400.
We are about to try some new Sanyo Ni-Mh that are in the 1800 range for the same sized pack. I like the idea of a battery that can be put on charge between flights or partially charged without causing a change in capacity. We have some 3300mah Ni-Mh for the big fellas too.
By the way, the new Futaba digitals (9550, 9350) are awesome. Very fast and tight. Not cheap, but awesome.
Mark
Mark
#382
Hey Mark,
awesome thread and wow, am I jealous of that plane... (stops to wipe drool off the keyboard.)
I have an 18 month old Alliance and have just bought a Synergy 90 and get a real buzz every time I fly them, they are superb. But you are right, the decals do make all the difference and make it really smart. Would you be able supply any ZN logos that I could apply to my planes? Or maybe some bitmaps that I could print onto vinyl? It would really complete them.
cheers, keep up the good work.
James
James
#383
Mark
A very impressive paint job, something I'm sure many of us aspire to achieve.
I was wondering what type of paint did you use for the Fuz?
How fuel proof is it?
Martyn
Martyn
#384
Graphics and paint
James,
For the graphics, please contact JP at the shop via the website.
Paint:
The paint is the brand Sikkens, a standard laquer base. It is covered with a high gloss clear coat that seems to stand up to 30% nitro fuel quite perfectly.
Mark
Paint:
Mark
#385
Mark,
Does it matter which way the mounting lugs are aligned on the MK bellcrank coupler. I notice most people have the mounting points horizontal. Is it OK to have it vertical - the unit does not need to flex as much in this position when tightening up.
#388
Mark,
Just glued my Synergy wings, before I start to laminate, a few questions:
For better bonding, do you apply epoxy to the wing surface before the first laminate is mounted? Is there a drying and sand period between each laminate?
I've seen people who apply three laminates in one time, is this advisable (It looked great when finished)?
Thanks in advance!
Pieter.
(You'll probably have nice weather in Romilly, while I'm enjoying epoxy smells on a hot attic.... )
Thanks in advance!
Pieter.
#389
Hello gentlemen,
Isaac, your best bet is to get a kit from Central and find a builder in the USA or scour the pattern sites for a used airplane. We are building to ARF level but we have a full calender for quite a while.
Pieter,
I don't really know what would be detrimental to laying the three laminates at one time other than you will get a lumpy overlap on the LE (I see doing the bottom three and the top three after those dry). I think that it is easier to sponge the extra epoxy out of a single layer at a time. Try the folks in the composite forum for more info.
Romilly was hot. I started out 33rd, went to 40th, and finished at 44th with each flight getting worse (I had no consistency). The competition was incredible and Christophe, Quique, Marco and W. Matt were awesome. Hell, all of the pilots were darn good. I have a bunch of photos that I will post in a Romilly thread shortly. I got back just 30 minuted ago so first I think I shall sleep for 12 hours.
Mark
Pieter,
Mark
#390
AK
Thank you!
Mark,
Thank you (!) for such a great article. Anybody who aspires to be a better craftsman can appreciate your work, and the photos were great.
Terriffic.
Terriffic.
#391
TX
Control Horn Questions
Mark,
First of all I'd like to say thanks for sharing in such detail your building techniques. It's always fun to see the different techniques builders use.
I'm very interested in the control horns you're using. I really like the way they extend out over the hing line. My questions are as follows:
1. Do you know if any of the hobby resellers in the U.S. carry these horns, if so who?
2. I noticed on the ZNLine web site the control horns are pictured with tiny little wood screws. Do you use these little wood screws or do you extend the screws through the control surface and anchor to plywood (or another control horn in the case of pull-pull) on the opposite side? It just seems like these little screws could pull out during hard snapping maneuvers.
3. What thickness aircraft ply is used?
KeithB
KeithB
#392
Control Horns
Hi Keith,
Currently, the control horns are available direct only.
The horns are anchored to a 3mm aircraft ply plate. For our airplanes, we cut a seat into the plate for the horn base leaving about 2mm. Yes, we use the original screws. I understand your concern about the screws pulling out as I had the same thoghts. However, seeing as none of ours have ever pulled out or even loosened, I have 100% confindence in this method. The screws extend fully through the plate and I use a generous amount of epoxy so there is even more bite around the tip of the screw.
Mark
Mark
#393
RE: ZNLine factory: Enigma Building
Hello Mark,
The thread of the Enigma building is a bit older now, but I;m using it as a guide line to build my Evolis.
So far all is clear, but I think I missed the part where you installed the MK-elevator unit.
Any tips around that?
Can the unit be removed/maintained when the fin-post is in place?
What is used to drive the unit. I mean what kind of pushrod is used between the servo and the MK-unit.
Do you need to go pull-pull here as you read at some other sites?
Thx again
Winfried
Thx again
Winfried
#394
RE: Control Horn Questions
Hello Winfried,
I did not actually do a step on the installation but it is really quite simple. It can easily be installed during outfitting the airplane or during construction after the stab and elevators are done. After selecting your control horns, mount your stab and figure out the best placement for the unit to provide the proper geometry for the horns you will use. Bore your holes in the fuselage (I use a conical grinding stone from Dremel Tools), send the center piece down the fuse on the end of your pushrod and link it up with the side bearings. It's easier to do than to explain.
For a pushrod we use a carbon fiber rod and titanium rod ends. We do put a pull cable (not pull-pull, just one pull) on the bearing to allow for up elevator should anything happen to the carbon shaft, but so far so good and we are making very many flights.
Regards,
Mark
Regards,
Mark
#395
TN
RE: Pushrod Installation
Mark,
What kind of arrangement do you use to support the pushrod? I assume you have something at midspan. Any pictures of this part of the installation?
--Derek
BTW this thread is one of the best building/construction threads I've seen on RCU. The only other one that comes close was a thread in Jets about painting techniques.
--Derek
#396
Pushrod support.
Derek,
Actually I have nothing supporting the pushrod. I have a large diameter rod which is about thee times the stiffness of the smaller rods and still much lighter in weight that some of those monster balsa beams I see used for that application. The smaller rods hold the ends and slip inside of the main rod. The main rod is cut to approximate length and then the short pieces of the inner sleeve with the ends can slide in so that the pushrod comes to the perfect length.
Mark
Mark
#397
Moderator
My Feedback: (58)
RE: Pushrod support.
"The smaller rods hold the ends and slip inside of the main rod. The main rod is cut to approximate length and then the short pieces of the inner sleeve with the ends can slide in so that the pushrod comes to the perfect length. "
Hi Mark,
I think this is a very nice way to install CF rods. Most std installations just use one piece and optimising the length can be a real pain, and wasted CF rods if not lucky. Could you post some pics of how you do this ? What are the diameters of the inner and outer rods ? What type of adhesive do you use ? Thanks...........Mike
Hi Mark,
#398
My Feedback: (21)
Mark, I read through this whole entire thread and I have never seen such clean, precise work! I just got to ask, what would one of those Enigmas cost to have as you have it there in the photos?
Steven
Steven
#399
IL
Bump for currency...
Guys, first time I came across this thread...spent half the night reading it. Most detailed buildup article I've ever come across! No wonder those planes have 4 digit pricetags
#400
BC, CANADA
Hi folks
I have changed the location of my building site directions to http://members.shaw.ca/patternwestnews/enigma.htm
Hope this helps those interested in building these ZN-Line and similiar type kits.
Dave Reaville
Dave Reaville
