X-Tech Infinity Tank Mounting
Hi
I am looking for some advice and maybe some pics of how people mounted the tank in the X tech Infinity. This is my first model of this type and I have several options on fitting the tanks so I am looking for some experienced advice.
Thanks in advance
Mike
Thanks in advance
Mike
Mike take a look a the ZN line site lots of pictures of tank instalations for their models [link]http://www.znline.com/list_photos.php?langue=english&cle_data=1025179850 &source=produits[/link]
or try the GB RCAA site where the is an excelent article on building a Synergy .[link]http://www.gbrcaa.org/ntoa/ZN%20Synergy%20Part%20III.htm[/link]
These should give you some inspriation, hope these help.
RGDS
Stevepj
RGDS
Stevepj
If you mount the tank around the c.of g. area, also make sure that nothing else can move,and pinch the long fuel lines---hold things like the rx battery,rx,&c., securely----velcro,tie-wraps,whatever---don't just wedge them with foam!
I say this from recent experience with a club colleague who should have known better---his pumped/piped OS 160 ran fine on the ground,not in the air----until we found that his rx batt. ,stuffed up front in foam, was shifting about and pinching/releasing the fuel lines....
