Old Rossi FIRE pattern engine
Old 09-06-2007 | 09:45 PM
Default Old Rossi FIRE pattern engine
I got this engine from a friend and want to know its characteristics and what prop should I use for a Daddy Rabbit. Is this the .61 or .65?
I believe Morris Hobbies used to sell this engine.
ID:	757971   Click image for larger version
ID:	757972   Click image for larger version
ID:	757973   Click image for larger version
Old 09-06-2007 | 10:03 PM
MTK
Default RE: Old Rossi FIRE pattern engine
ORIGINAL: rmazuera
I think its the 65.
The 61 had a black head I believe. Good budd Gary Kirby used the non-pumped 61 way back in early 90's in Jax. Turned a 12x12 apc with authority on a slightly stretched pipe, 20% nitro and KB1L plugs
The 65 should turn a 13x10-11 or a 14x9. Set the high point of the pipe at approximately 15" from the exhaust flange, straight line.
MattK
Old 09-09-2007 | 09:11 AM
What kind of rpm should I expect with these props?
Old 09-09-2007 | 10:05 AM
My Feedback: (9)
should turn 10 to 12 thousand maybe more
