Contest Balsa Source?
I'm sure you probably have heard that Lonestar Balsa burned to the ground just before Thanksgiving. It was a horrible tragedy from what I can see on their website.
So my questions is - where do others buy contest grade balsa? Not necessarily looking for the cheapest source - just great quality contest grade.
Ken McGuire
Ken McGuire
My Feedback: (18)
GA
Haaaa...I was just researching that myself...How Funny!! Now I have never bought "Contest Balsa" before so I'm no expert...But from what I've read this morning...Sig seems to be pretty consistent with good stuff...There are a couple more sources that guys mentioned but it really seems everyone shopped at LoneStar...What a shame...I hope they decide to re-build!! It's got to be hard on those folks to loose all the data and everything like that though...
Anyhow...Here are some links I came up with:
Sig - Main Page:
http://www.sigmfg.com/cgi-bin/dpsmar...FV4.html?E+Sig
Sig - Balsa Page (Note: Click on the photo of your desired item to expand to details):
http://www.sigmfg.com/cgi-bin/dpsmar...alsa_20Wood_01
Here is another but have little feedback on these guys:
http://www.nationalbalsa.com/balsa.htm
It seems another name I saw allot of was Superiorbalsa...But could not find their site...Wonder if their still around??
Hope that helps a little??
Have Fun...
Chuck
Sig - Main Page:
Have Fun...
Chuck
My Feedback: (7)
I used National for my last order which was about a year ago. I live close enough to have gone to them for pickup. The quality is as good as I ever got from Lonestar from whom I've ordered several times.
The owner of National is a straight up guy and runs a nice operation. Prices were about the same as Lonestar's.
ORIGINAL: bokuda
But Lone Star generally cut their stock oversized in length and width and that sometimes worked out better for some applications
MattK
What about this guy ? Max and below 6 pounds/ ft3, seems okay for 1/16 x4 x36 sheeting. If all sheets are like that even the price seems fair. If you order "unsorted" you will end up having three or four good sheets out of 30-40 ....
http://www.specializedbalsa.com/
Just a word to the wize here about 1/20th balsa sheets. I used some of this to sheet a foam wing for a half a pylon racer. I covered most of the plane with Ultracoat and used a 12" or so swath of Moneykoat for a racing stripe of one wing. (I liked the color and couldn't get it in Ultra.) The foam under the higher temp Top Flight stuff melted leaving a nice dished out surface in the wing. Under all the Ultracoat all was well. I'm sure some of the thickness of the 20th balsa had been sanded off, Just a heads up as to what can happen. I also had used Lone Star Balsa, got my last shipment from them the day of the fire. Wish I had ordered more.
My Feedback: (90)
Definitely very minor sanding on the 1/20th and set the temp. of the iron moderate.
Also plenty of CF strips for additional strength. I used all my 1/20th s on a pair of wings for a gas pattern ship. Hold very strong.
The problem is nowadays you can not get 1/20" from the two Blasa shops. 1/16" or 1/32".
i just got my order in from national balsa. the quality seems ok. anybody have any weights offhand to compare to? i can go weigh a few different pieces for comparison. there may be someone who wants to compare.
david
david
