ROLLING ROLLING ROLLING
Old 01-28-2008 | 03:31 PM
EL TEMUCANO's Avatar
Default ROLLING ROLLING ROLLING
WHELL , HERE A'M AGAIN. WITH MY POUR ENGLISH...
I'M PRACTICE ON MY PRO DELUX SIMULATOR A LOT OF ROLLS. I WHANT TO DO 1 - 7 - 10 - 400 ROOLS WITHOUT STOP......
MACKING 8, LOOPS, 360, GOING UP, GOING DOWN....... A LOT OF ROLLS.
NOW I CAN DO 360 WITH 2 ROLLS OR A LOT OF ROLLS, BUT IF I WHANT TO CONTINIU WITH A 8 , #@!*&^*&%#^&*%^%#$%$q@ I CAN'T DO. )$*@##&$%@!$)(............. IF I USED ONLY ELEVATOR I CAN DO , BUT THE REALY DIFICULT IS DO IT WITH RUDER...
IF ANYONE DO SOMETHIG KNOW SOMETHIN TO DO "EASYEST" PLEASE WHRITTE HERE..... DONT SAID PRACTICE - PRACTICE - PRACTICE.....
THANKS A LOT
Sergio
www.aeromodelismo****co.cl
Old 01-28-2008 | 04:27 PM
Default RE: ROLLING ROLLING ROLLING
Sergio,
Assuming you want to do a rolling horizontal figure 8 with "a lot of rolls, try this mental picture.
Imagine you are looking down on your model plane from directly above it. Starting from a straight and level flightpath, you begin by rolling to the right. As the plane rolls right 90 degrees, canopy is to the right, so that the wings are vertical to the ground, you pull up elevator and release elevator back to neutral as the plane rolls inverted. As it continues to roll right to 270 degrees, canopy is to the left and wings are verticle to the ground, you push down elevator and release elevator back to neutral as the plane rolls upright. You continue this procedure until you have completed a horizontal rolling circle, which is the first half of your desired horizontal rolling 8.
Now you reverse your roll and start rolling to the left. Continue using elevator when the wings are vertical with canopy left (up elevator) and canopy right (down elevator). Continue this until you have completed a rolling circle to the left, which is the second half of your desired rolling horizontal 8.
This maneuver can be done using up elevator and no down elevator.
Try it both ways and see which you prefer.
Remember to do this while flying 2 mistakes high.
Regards
JC
Old 01-28-2008 | 05:02 PM
OK, I CAN DO THAT WITH ONLY ELEVATOR, BUT WHEN A WHANT TO DO A VERY BEAUTIFULL ROLLS A HAVE TO PUT SOME RUDER AND THEAR IS MY PROBLEM. I CAN DO A 360 WITH ELEVATOR AND RUDER BUT IF I WHANT TO CONTINIU DOING SOME 8,,,, I CANT DO IT.
REGARDS
Old 01-28-2008 | 06:45 PM
ORIGINAL: EL ****CANO
REGARDS
You might try to practice this maneuver by simultaneously mashing potatos and tossing a salad with your left hand hand , while twirling spagetti with a fork and trying to eat jello with a butter knife with your right hand. Since you want to use rudder in your rolling circle, just remember...when your canopy is 90 degrees to the right, you kick left top rudder. When your canopy is 90 degrees to the left, you kick right top rudder.
Good luck.
JC
Old 01-28-2008 | 09:59 PM
you can´t do ,,, realy????????????????
thanks...
