Jaccio regulator weights?
ORIGINAL: Troy Newman
The one I have just weighed 11g
This is not the perfect switch version just the regulator
Troy Newman
Troy Newman
Jim O
Me and several of the guys I fly with are switching to the Duralite DigiSwitch. It is a switch with built-in 5.5V regulator and voltage monitor. It can be set up to monitor a 2-cell lithium or 5-cell NiCd battery. According to the manual the weight is 15 grams (15 grams = 0.529109429 ounces).
ORIGINAL: mjfrederick
Jim O
My Feedback: (23)
ID
I'm new at 6v receiver packs and would like to know what type of connectors to use between the perfect switch and a 2s LiPo pack. I'm asking because the pack wires are considerably heavier gauge wire than the perfect switch wire. My power systems, watts up and charger are setup for 4mm connectors. Therefore the most convenient would be to use 4mm bullets between the pack and switch/regulator. Is there a better way?
My Feedback: (45)
On a pattern ship it really isn't that critical. I still use the standard Futaba plugs for all of mine. We arent using near the current that the big birds are on our pattern setups. You can use the heavier connectors, but they are just unnecessary weight.
Arch
Arch
