Landing Gear!!!!
Old 05-10-2003 | 01:53 AM
Default Landing Gear!!!!
Question,
I need to get my plane off the ground a little more. I have an Aresti .40 from Hangar 9. The included wheels are the right size, but the swept gear is too low for the 12" prop I swing on my .61 engine. How important is the LOCATION of the wheel compared to the C.G??? This is a tail dragger. I need to get a diffrent gear to add at least 1" to 2" off the ground... The gear is SWEPT bakwards, but I was told that the gear should fall in the same place compared to the CG. I can't seem to find any swept gear that will work. Any suggestions???
Thanks.
Old 05-10-2003 | 01:57 AM
Warren's Avatar
My Feedback: (72)
Having the wheels another inch forward or so on this plane should not be an issue.
Moving it back towards the CG is where you can run into problems quick.
