bellcrank
Hi,
I want to install the MK Bellcrank on my 90 size pattern, what CF diaimeter size i should use ? is that ok to connect the CF directly to the bellcrank ? do i need to support the CF to the fuse ?
WA
An 1/8in will handle the forces, but would require frequent support points (every 2-3 inches) to keep it from flexing and vibrating. 3/16in would let you increase the span between support points, maybe to 6 or 8 inches.
I've used the M&K bellcrank on two pattern planes, and I can't recommend them. The need for supports to keep the rod from vibrating and flexing is a pain to install, and both of mine got sloppy with flight time. The fit of the two halves start out pretty tight, but the plastic spreads where they join and after a couple of years gets a couple of degrees of slop. Having the two elevator sides varying a couple of degrees is huge in pattern.
I switched to the DEP system and have better experience. It uses continuous support, and there just isn't any place for slop to occur, except where the clevis's attach to the servo and elevator. Price is about the same. When you look at DEP, it looks like more work, since you must build this support ladder, etc. Maybe for the first build, it takes more time to figure out, but once you do one, it gets easier. Plus the bellcrank has its installation problems also. For example, if your fuse sides are not parallel where you are mounting the bellcrank, and most are not, then the bellcrank won't mount flush on each side, and you end up making shim pieces to go on each side so the bellcrank can mount parallel. Also, trying to hook up that long rod to the bellcrank back there with the narrow spaces can be a bear. I've had to cut a hole in the stern bottom to snap on the long rod clevis not what I wanted.
From what I've read, DEPS seems to be the most long lasting, slop free way to install linkages to the elevator halves. It isn't extremely expensive either. The only downside is that it does take time to set up inside the airplane, but that's a one-time thing.
IN
I use the 5/32 carbon rods and titanium ends frm Central Hobbies. I lost an airplane due to pushrod vibration so I always use some type of support. A piece of foam that the pushrod is pushed through and the foam slid back in the fuselage untill it is snug works good. I have used bell cranks on meany airplanes and if set up correctly they work good.
I have being using the CH 5/32 and the MK bellcrank on my Osmose YS power, never had any kind of problems, I'm not planing to change to twin servos soon, the DEPS system which I also have, suffer form trim changes with temperature a lot.
Regards
Regards
