XIGRIS name of new ZN Line Plane
#57
RE: XIGRIS name of new ZN Line Plane
ORIGINAL: papaone
Hi Jeanmi
She is very pretty.
A+
Hi Jeanmi
She is very pretty.
A+
It looks fantastic. Colours scheme is very nice.
What is the final airframe weight ?
Cheers, JB
#58
I start toonight the final of the building.
Servo 9650 for elevator (2), 9650 for throttle, 9154 for aileron, BLS351 for rudder
engine is YS 170 with sparkignition becker for the first xigris and 170DCI for the second
2 lipo 800 m1 2S FPower with 2 emcotec DPSI RV for each plane
Lipo power for spark ingnition wtih picco switch in order to start spark with the transmitter
photos coming soon
photos coming soon
#59
Hi Xigris,
I like the colours scheme, I find it very original.
I'm very interested to know the weight that you'll get with the material you chose.
I look forward to the pictures of the plane in flight order.
Best regards
Best regards
#60
Hi Papaone
I noticed that Frederick did this before covering started, do you no if it is sillicone or epoxy/microbaloons mix?
Maybe one can use epoxy/microbaloons for this filling job- and once it is finnished(sanded to profile plus covering) you can apply packing material applied with doublesided cellotape to reduce noise and scuffing .
Gerrie
Gerrie
#61
ORIGINAL: gerrie
Hi Papaone
Gerrie
Hi Papaone
Gerrie
Regarding the filler; looks to me to be silicone applied solely to get rid of any vibrations (scuffing) between the two surfaces? In that case, microbaloons won't do.. (correct me if I'm wrong). I'm using a "filted tape" for this. (The kind used on picture frames - adhesive on one side, slightly furry on the other..). This was applied on one of Ola Fremmings' old planes that I had, and I kind of stuck with it!
#62
Hi Gerrie
frédéric told me he put epoxy/resin/microbaloons mix. He sanded it to profile and put Oracover.
To reduce noise and scuffing we put adhesive thin foam insulation.
Claude
What's new about your Addiction ?
Claude
#64
Hi Papaone
Still busy with painting the Addiction,it rained a lot here and then the compressor had a problem-this made painting very frustrating and I want an immaculate job on her.
So I started with my Osmose (carbon/honeycomb delux version... kit) which was laying around for quite a while .
I like the way Frederick used to mount the tank ,want to try the same thing in the Osmose - sturdy and saving weight ...can leave out that pipetunnel floor.Also considering that rudder modification.
Currently flying a composite arf Integral/YS 160, LOVELY PLANE,but very fragile. Our runway is not the best and started to wear that fragile landingear mounting area t after about 190 flights.
Leaving for the Nats.(23-26 April) tomorrow- which will be held at Port Elizabeth-known for very windy conditions.
#65
ORIGINAL: papaone
Hi all
Update link with a lot of pics
Great job made by fred.
http://picasaweb.google.fr/FredericV...at=directlink#
Hi all
#67
Hello, now 4 flight were performed.
All is fine
It's marvellous plane is as slow as an electric ...
I love Spark ignition Becker and the second with 170 DCI may be probably nice...
All is fine
#73
ORIGINAL: XIGRIS
All is fine
All is fine
