APC 18.1X11W
Hello,
Does the APC 18.1X11W exist as I'm having trouble finding it? On the Tower Hobbies web site http://www3.towerhobbies.com/cgi-bin...&P=WR&I=LXRCJ5 the heading is for 18.1X11W but if you look at the data is clearly states that the prop is 10" pitch. Other web sites also have this apparent contradiction: https://www.toysonics.com/apc-18.1x1...-lp18110w.html
So what's the deal?
Thanks.
So what's the deal?
Thanks.
CA
ORIGINAL: rcpattern
Adrian,
Are you running the 18X11 WPN on your 1.70s? I talked to Richard at YS and he said the Japanese are using these and repitching them to closer to a 12 and they really like them. I've ordered 2, but haven't tried them yet,
Arch
Adrian,
Arch
Yes, I've been using them for the last 3 months. One of my team mate repitched them to 11.8 for me, and its a real nice prop, up line is near perfect. If you set your throttle curve correctly, you can feel the torque increases on every single click. However, I found the down line is still a little fast. I'm sending him a few more to have him try a slightly different pitch. I've tried the regular 18x11 WPN on the 170, not enough prop.
Adrian
I contacted APC who informed me that they only do the 18.1x11 and 18x11WPN.
Adrian, how did you find the downline with the WPN compared to the 18.1x11? How did they compare load wise? Sounds like the WPN is a lighter load. If the Japs are repitching them closer to a 12 then why not just use the 18.1x12? Its ashame APC don't do an 18.5X11.
CA
ORIGINAL: Tangy Tom
As for why they don't use the 18.1x12, I believe one of the reason is the shape of the WPN. Believe me, I have sent a few of those 18.1 props to Naruke before the 07 WC, he actually came out with a 17.7x11.7 for the 170, and I have been using them last year before I received the re-pitched WPNs.
Adrian
