OS 160 tuned pipe
My Feedback: (12)
AL
I, and many others, have used the Aeroslave pipe successfully with the 1.60. www.aeroslave.com
Hatori 902 (probably in stock at Singahobby) or the 520mm pipe from f3alorenz.de, http://www.f3alorenz.homepage.t-onli...lldaempfer.htm (I'm using that on my 160)
My Feedback: (42)
NJ
Either the Aeroslave or the ESare good ways to go. You may get a little more power out of the Aeroslave, but it can be aslightly peakier than the ES. The EShas a mellower sound IMO, but it's not a very big difference. I've run the MACS pipe in the past and it makes a considerable amount of power, but it is less friendly to set up, relatively loud and tinny sounding by comparison with the Aeroslave or ES and definitely heavier. It is also has jumpiest response of the 3.
Tach figures for My OS 160: 8100 rpm, idle at 1500rpm.
15% nitro, APC 17x12, Lorenz pipe at 70cm (total length from start of header to end of pipe) OS #F plug, Perry pump.
My Feedback: (7)
OH
Tach figures.... OS160FX Hatori 907 header ES 7/8 inlet pipe Perry VP 30 OS F plug 15%Ritches Brew. 8200 RPM with 18.1x10 APC Prop. 1/4" gap between header and pipe per Jason Shulman. Replace rear bearing with stainless. Tap upper left backplate hole for OS140RX EFI pressure tap for pump. Back out pump screw 2 turns. Turn in low speed needle 2 turns. High speed needle 1.5 turns. Choke with verturi open and prop thru 5 revolutions. This should get your finger wet. Close venturi and prop through 3 more times. This should get fuel to plug. Now place glow igniter on and briskly back flip motor clockwise. If you have fuel in the cylinder , it should fire. This is the procedure I followed on the last OS160 NIB and it fired up the second back flip. We now have 3 flights on a fresh Black Magic VF3 and the motor has been flawless. I have used this setup on four different planes both pumped and unpumped and it is super reliable and makes great power. There maybe some more tweeks to improve power but I,m very happy with everything! I will leave well enough alone. This set up with the ES pipe has a nice mellow note and great throttle response. All this info is stollen from Jon Lowe and is known as the Jon Lowe Cookbook set up. Read it for youself on rcaerobats.com.
RC Flip and Fly!
RC Flip and Fly!
My Feedback: (12)
AL
I generally found you do not need to change the stock pump setting at all. Some people do, and if it works, that's fine. I recommend leaving it alone and only changing it if the engine runs too rich everywhere. You also need to add an OS bubbleless clunk, or the YS foam equivalent, to your fuel tank, as this helps keep the engine from leaning out from airbubbles as the tank level drops.
I found that I could gain 150 to 250 rpm by using an OS 86 carb from the old OS .61 RFP ABC-P engine. You have to drill and tap the carb for the mounting screws. The carb from the OS 1.40 RX works well also. Both have larger bores than the stock 1.60 carb, and are designed for pump operation. Tower Hobbies sells a plug (part # LXCT39) that will close off the stock needle valve hole so you can use a remote needle. You also need to block the fuel return port on the 86 carb with a screw of the appropriate size.
The best prop I found is the APC 17x12W. This is not a common prop, but I was able to get them from Central Hobbies. This prop gave better pulling power on vertical uplines than the 18.1x10. This seems counter intuitive because of the larger pitch, but it is a lighter prop, and seems to spool up and down better.
After three broken crankshafts in one year on a couple of engines, I did two things. I stopped using the 18.1x10W prop (the 18.1x10 seemed to work fine), and I used a dremel tool to remove the sharp edge at the back of the crank port, radiusing and polishing it. All three had sharp edges there, and cracks propogated from that point, and went around the circumference of the crank. All three failures were identical in nature. The 18.1x10W prop is very heavy, and was likely exacerbating the issue. I radiused the sharp edge and changed props at the same time, so I don't know which ultimately solved the issue, but I never had another problem with any engine after that. That is a routine mod I do now on any new 1.60 when I change out the junk rear bearing before running it.
This proved to be a very trouble free setup over several years of flying. I went to YS power late last year because the OS 1.60 just can't compete on low end torque and throttle response to the YS 1.70. It could up thru the YS 1.60. I do miss the cheap fuel costs and fuel economy of the OS though. And I could buy a whole new engine for the cost of parts for a rebuild of the YS!
My Feedback: (18)
RC11,
I tried to send you a PM but was unable to. It is weird, I can type the message and add aimages with no ptoblem, butthere is no button to send it. I just get a message that says "html type mismatch error".
Anyway, I have two pipes that you can use with your OS 160:
I have a used ES two stroke carbon fiber pipe. It is extremely light and in good shape. The only thing about it that is not perfect is a small scuff toward the neck right behind the reinforced part (there is an aluminum ring at the front opening to offer support when the pipe is clamped to a header). I think I clamped it a little tight and managed to scuff/distort it slightly. You can't even see it in the pictures but you can feel it a little bit. It does not seem to effect the operation of the pipe. This is a non tuned pipe and is very quiet.
I also have a NIB OS tuned pipe, the one that was designed for the OS 140 I believe. I have no reason to believe it would not work very well on your 160. It is in perfect condition and has never even been removed from its packaging.
New the ES pipe was $169 I think, I would take $65 bucks for it shipped
The OS pipe is in stock at Tower hobbise P/N # LXCC51 and is listed for $264.99 I will let that one go for $85 shipped.
Let me know if you have interest in either.
Anthony
My Feedback: (18)
RC11
DUH!!!!
I am so slow, I just figured it out when I saw the city you live in. RC11, Rick Cilles, dude, I don't know why it took me so long to put two and two together. St. CLaresville, Black Magic. I am truly embarrassed.
Give me a call and we will work out the deal on the pipe!
Anthony AKA "Sponge Bob Scrub Pants"
My Feedback: (18)
For some reason I can not send PMs, I can only receive them. If you are interested ina pipe please email me at [email protected]
Anthony
