Engine for a WM Zen 120
Old 06-23-2003 | 05:18 AM
tedginto's Avatar
My Feedback: (45)
Default Engine for a WM Zen 120
I have just started to fly pattern ships. I have Tai Ji 40s and put a Saito 72 on it after I flew it the first time with a Saito 56. I would rather not buy two engines for this model. Any suggestions would be greatly appreciated.
TIA
Ted Edginton
Old 06-23-2003 | 01:04 PM
Two banger or four banger?
Old 06-23-2003 | 01:17 PM
tedginto's Avatar
My Feedback: (45)
I would prefer a four cycle.
Ted
Old 06-23-2003 | 04:05 PM
My Feedback: (12)
YS 140 FZ, L, or DZ!!!!!
Then you won't have to worry about finding something better!!
Old 06-23-2003 | 04:07 PM
tedginto's Avatar
My Feedback: (45)
Kul
Thx
Ted
Old 06-23-2003 | 04:40 PM
My Feedback: (15)
Default WORLD MODEL 120 ZEN
I have be fly a ZEN120 for the last to 2yrs, a YS 140 is to much power. I'm started with a YS120 then swith to Webra 120 RE
with a Hyde Mount. With the mount that comes with the ZEN 120 it is setup for the YS. is the best combo. an stick with it trust me.
the Model fly's great. and the exhaust system fixs inside the belly pan, also if you want to with a 2 stroke system buy the new Webra 120 side exhaust with the pump for $239.00 vs YS120FZ
$379.00. the Webra is user friendly,an the YS140 is to much power for the airframe & the soft mount system that come's with the ZEN 120 ARF
I hope the info helps
Old 06-23-2003 | 07:18 PM
How about a second hand YS 120, or the new YS 140 Sport?
Throttles go up aswell as down. I think I saw on Ola Fremmings site a guy using an OS 140RX.
Old 06-23-2003 | 08:28 PM
My Feedback: (15)
A second hand YS120 should work, I was using a YS 120 FZ, You can still get them, but it was replaced by the 140 sport, In which it
is aYS140L with a diffirent carburetor. OS 140 will work, but you will need a diffirent motor mount, but i do think the bolt hole patterns are the same. Then also you will need to cut the rear of the fuse for the long tune pipe, which is not hard. Myself i'll go with the 140 sport but the YS120 will work
