P-11 Figure M
#76
RE: P-11 Figure M
Guys,
... "M" is one thing, another is #7 ( loop with 8pt roll integrated over the top 180 degrees).
I did the program today, and this one needs a lot of practice to look nice ...
Kjell Olav
Kjell Olav
#77
RE: P-11 Figure M
Hello
I found I good explanations of the P-11 program. Hope it helps!
"open the link, and when it opens, click the left button on the mouse and get the SCHEMATIC MANOEUVRE ILLUSTRATIONS"
http://www.ofremmi.info/F3A/Schedules/Schedules.htm
PS. go down on the side and look for (Maneuovre list P-11 Detailed description as powerpoint presentation, made by Peter Uhlig)
Good luck
/Roland
Good luck
/Roland
#78
RE: P-11 Figure M
Wow. The more I fly the Figure M the more I'm starting to think i might have to go "gay" and buy a tx tray. I just don't have the dexterity to feed gobs of rudder in smoothly (when going from left to right, M1) without feeling like I'm going to crush the transmitter inwards!
how about you guys?
how about you guys?
#79
RE: P-11 Figure M
ORIGINAL: sarashina
Here it is.
sarashina
ORIGINAL: Hans Meij
Can you point us to complete ribbon-scheme?
Thanks, Hans
Thanks, Hans
sarashina
Hi,
Do you have a ribbion view for the P09 sequence? it would be great for learning
#80
RE: P-11 Figure M
I hope you meant the p-11 sequence. I was able to find the ribbon sequence on the Australian pattern association website.
Hope this helps
Edit- new link works...sorry.
http://www.australianpatternassociat...au/index2.html
Hope this helps
#82
RE: P-11 Figure M
ORIGINAL: sarashina
Hi,
If it is needed yet.......
Hi,
Ok so masters only fly the P-11 sequence ? & not the P09..
Is there any video of the P-11 sequence..
i am flying a Astral in my AFPD & fly quite good its cheap.. for me to practice the sequence
Harry
#83
RE: P-11 Figure M
Masters has a completely different sequence given by the AMA not the FAI. you can find the masters sequence here.
http://nsrca.us/ama-classes/masters.html ( Call Sheet )
http://nsrca.us/documents/judging/cu...asters2009.pdf ( power point Presentation)
