Showume 50 engine
Old 10-06-2009 | 03:10 AM
Default Showume 50 engine
Hi there all
I have just acquired a showtime 50, with some very slight damage. My question is, will I be able to fly this OK with an OS .40 two stroke? I am not looking to do any crazy 3D stuff, just loops, rolls etc.
If it will be underpowered would a tuned pipe be a good idea?
Any thoughts appreciated
Gareth
Old 10-06-2009 | 04:29 AM
tIANci's Avatar
Default RE: Showume 50 engine
Underpowered for good performance even if you meant a 46AX ... if you can, go with a Saito 82 or OS 55 ...
Old 10-30-2009 | 11:59 AM
I would say minimum an Evolution 52 which is in mine. It flies great with that setup, but I crave a little more power. An OS55 would be about the same as the Evo 52 I have two of each they are similar. I would put the new Evolution 60 hot rod engine in it if I could do it all over again, actually I think I just will do that anyway.
Old 10-30-2009 | 04:58 PM
My Feedback: (182)
Why not try the new Evolution 60NX that is actually smaller 60 size engine??
it should fit without any problems since it was designed to fit on 40 size.
http://www.horizonhobby.com/Products...rodID=EVOE0600
Ihncheol
Old 11-02-2009 | 01:37 AM
Thanks everyone
The reason I asked is that I have a spare .40 lying around and a repaired example of this plane is bein sold for almost nothing at my LHS.
Will just try and find another pattern plane for my .40
Gareth
Old 01-05-2010 | 06:44 PM
So my OS 61 should work fine on the showtime 50?
