DS8411 servo gears
Old 10-17-2009 | 01:14 PM
Default DS8411 servo gears
Hi, I purchased a second hand OTOP 2M ship that has JR DS8411 servos, the standard version with the metal gears. Do the DS8411SA nylon gear set fit in the standard 8411 servo? I have received conflicting information, and would like to know if anyone has installed the SA nylon gear set in the standard 8411 servo. If they do fit any suggestions on when I should change out the existing metal gears with the nylon ones. There is no noticable slop in the present gears, but the general consensus appears to be that nylon are better for pattern ships.
Old 10-17-2009 | 01:32 PM
My Feedback: (55)
Default RE: DS8411 servo gears
The gears will interchange. The reason pattern fliers prefer nylon gears is they have less slop
and stay tighter longer. The metal gears get loose after flying awhile especially with a hard
banging 4 stroke. The nylon is slightly lighter also.
tommy s
Old 10-17-2009 | 01:49 PM
Don't change out the metal gear that the servo arm fits on. It's not necessary and it's a pain to do.
Joe Dunnaway
Old 10-18-2009 | 12:11 PM
Thanks Tommy S and iflyrctoo, appreciate the feedback.
Regards
Clint
