Questions from a Pattern Flyer
My Feedback: (8)
(I figure I ask enough questions and felt bad taking over the crappola thread)
I just got some Rx batteries with 16 gage wires but no connectors. What is the right connector to use, to plug into a regulator? It is for an electric plane so they will be plugged/unplugged every flight.
Tech-Aero regulators generally come with a JR female connector, but it seems like 16ga wire is too big for [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPNU0&P=7]that type of connector[/link] (they are for 20-30gage). I can ask Ed to install a different connector, or replace the connectors when I get the regulators.
My Feedback: (42)
NJ
RE: Questions from a Pattern Flyer
ORIGINAL: gaRCfield
The reason there is 16 AWG wire on those batteries is so that when used with an ESC and a motor for pulling an airplane around, that it will be able to deliver the higher current loads with minimal voltage drop. The kind of current demanded by servos in a Pattern airplane is quite low by comparison. It's no issue at all to adapt the heavier gauge wire to a connector into a regulator. The best way I can recommend is to use Deans mini connectors. If you want, you can send me the batteries when you place the regulator order and I will do the soldering for you on the battery side of things.
NY
ORIGINAL: gaRCfield
Can anyone recommend a good scale, maybe with a link? I want to start weighing my planes and components.
NY
Here's a scale at a good price http://www.walmart.com/catalog/produ...i_sku=11742235
My Feedback: (8)
Since planes must be under 5kg I figured I'd need at least that for a limit. I was wondering what other guys are doing as far as weight limit and resolution. Went to local Walmart, Staples, and a few other places and none of them had an appropriate scale.
I'm getting ready to get out of this state
I'm hoping my next project after the Wind 110 is a kit, or at least a 2M electric plane. I want to learn how to plan and measure everything to do it right and stay under weight.
My Feedback: (18)
Joe,
Here's a scale that will weigh up to 7kg and won't break the bank:
http://cgi.ebay.com/MY-WEIGH-7001-PO...item35a4a65952
Joe B.
Joe B.
My Feedback: (58)
Joe,
I use two scales. This one which has a 2 gram resolution:
http://cgi.ebay.com/ULTRASHIP-35-DIG...item35a4a6bd6d
and then I have a smaller more accurate gram scale for mixing epoxy or weighing items up to 1kg in .1gr increments.
ORIGINAL: gaRCfield
My Feedback: (8)
ORIGINAL: 1bwana1
I second the use of Deans mini-connectors, but why would you plug/unplug after every flight. Why not run through a charge capable switch? Much easier, and more convenient.
ORIGINAL: gaRCfield
My Feedback: (8)
What are some good kits to look at for a first build? I was looking at the CA Epsilon but it seems like they do quite a lot of work for you with sheeted wings and pre-built stabs.
Does it make sense to start with a smaller, cheaper kit for a first build? I imagine so...
