Is a biplane best fit for P-11?
Old 12-10-2009 | 09:36 PM
Default RE: Is a biplane best fit for P-11?
ORIGINAL: DaveL322
The 1/4 loop entry, 1/2 loop in the middle (with the integrated 1/2 roll), and the 1/4 loop exit should all have the same radii. Not easy.
Very difficult to make the bottom M tight integrated with a 1/2 roll.
Is a biplane performing tight KE loop better?
And of course there should be a defined straight line after the M before the 1/2 Rev Cuban turnaround. Very difficult to fly this maneuver at <175 meters geometrically correct AND have it look smooth.
Attention must be paid for this maneuver since exceeding 175 meters would be downgraded.
Eric
Old 12-11-2009 | 10:53 AM
DaveL322's Avatar
ORIGINAL: ericng
Depends on the biplane.....planes with the greatest amount of side area (all other things equal) should be able to make the tightest KE loop.....this is not necessarily a biplane.
ORIGINAL: ericng
>175 meters SHOULD be downgraded....doesn't mean it will be.....and the new sequences very clearly favor presentation further out than the prior sequences.
Regards,
Dave
Old 12-11-2009 | 12:36 PM
A Biplanes rudder authority comes from more than just side area. The arrangement of the wings funnels air or does some other voodoo magic to increase rudder authority. I personally have not flown the sequence yet because of school getting in the way, but I'm curious/excited to get started on it and see where the biplane comes in handy.
Old 12-11-2009 | 08:58 PM
Also, relatively less wing span and with the flat interplane struts provide more rudder authority to yaw the fuselage during KE loop from downward to upward.
Eric
