Redundant RX pwr. UBEC + Lipo. Only Tech-Aero?
NY
First off please forgive me if I ask folks to refrain from "bashing" UBECs in F3A. I am fully aware of the concerns, and the unorthodox nature of this approach right now. Point being I'd rather not have this devolve into a debate, but rather stay focused on the possible design and hardware options involved.
So . . .
On my first 2M ship there was a dual input/single output voltage regulator. Before I got it, Joey Hayes had been running the plane with two Lipos in a "Hot Battery Standby" configuration. Meaning only one battery was being used at a time, and the second battery would only turn on if the regulator could not maintain the selected output voltage using the primary battery. When I took the plane home I installed a [link=http://www.dimensionengineering.com/VHVBEC.htm]Dimension Engineering VHVBEC[/link] and put that in parallel with a Lipo. The result was a redundant RX power system where the output normally came from the VHVBEC, but had a regulated Lipo as a backup. My question is:
Is the [link=http://www.tech-aero.net/plr5-dr2]Tech-Aero PLR5-DR2[/link] the only dual input regulator that allows a "Hot Battery Standby"?
Is there a more elegant unit that combines a BEC plus a second power source in one package?
I am interested in this because I believe it offers the following advantages:
1) RX power redundancy.
2) Few if any RX battery charges required.
3) The ability to fly with no RX battery in a pinch.
4) Constant regulated output voltage for unchanging servo response.
I am fully aware that complexity brings dangers, but I am willing to try none the less . . . although I admit that I am only "considering" this and am most concerned that there would be a significant weight penalty plus the fact that it may be a bit of "over engineering" when a simple 700 mAh 6v NiMH will do an excellent job with little chance of failure and no added complexity In fact as I write this I'm just thinking that the unit, whatever it might be, would create a potential single source failure point which wholly defeats the design. Anyways, I'll stick with my original question:
What's available?
Thanks as always,
Joe P
So . . .
What's available?
Thanks as always,
Joe P
My Feedback: (10)
TN
RE: Redundant RX pwr. UBEC + Lipo. Only Tech-Aero?
Try this:
http://www.hangtimes.com/id33.html
Unless you really, really feel the need to reinvent the wheel. . .
My Feedback: (8)
I wonder if Ed could make something custom for you - that would be my first route
So you're after a UBEC that uses the 10S lipo for Rx power, and has a second/backup input for a small Rx battery in case of failure? I think it's an interesting idea.
My Feedback: (42)
NJ
All you should need to make hot standby configuration for a UBEC is a single linear regulator set to, let's say 0.1V to 0.2V lower than the UBEC. If the UBEC fails, you have an instantaneous cutover at the slightly reduced voltage level of the backup regulator. Ideally, the backup regulator should be a good one, i.e. a very low dropout design.
NY
I've been using the two items shown below in Joey Hayes' old Integral with great success so I know that the idea works, but I'm hoping to find something even lighter than the Tech-Aero which is .6 ozs lighter than the [link=http://www.maxxprod.com/mpi/mpi-21.html]MPi ACC135 regulator[/link] which is currently in the Integral . . .
. . . and kl - one of the main parts in my question was the desire to use a BEC as one of the power sources. Do you think the Hangtime's regulators can use one side or the other versus both inputs at the same time? It didn't appear to me that that was how they worked, but if I missed something it certainly wouldn't be the first time
Joe
Joe
NY
ORIGINAL: NJRCFLYER2
Hi Ed,
Thanks for chiming in. What would the two outputs (UBEC/single reg) plug into? Would both plug directly into the RX?
Joe
NY
Wow! It's that simple?!?
The regulator prevents current from the UBEC reaching the Lipo, and as long as the UBEC has a higher voltage than the regulator no current will flow from the Lipo. Is that about the gist of it?
I can't imagine why more folks aren't running this? The VHVBEC from Dimension is only 17g, and one would only need an absolute minimum sized Lipo as a backup say a 480 or even a 250. The total setup UBEC+regulator+Lipo would weigh less than 2 ozs.
I can't wait to give it a try . . . hey . . . I think I'll go downstairs and try it right now
Thanks again Ed!
My Feedback: (42)
NJ
My Feedback: (10)
TN
Joe,
Sorry, I read your original post too quickly and thought your airplane used a "real" engine. . .
ORIGINAL: 2Sunny
Joe
Joe
ORIGINAL: 2Sunny
A couple comments -
1. Lipos really don't like to be stored long term at full charge....so in the application you are describing, it would be important to regularly check the back up lipo.
2. The Dimension site lists the VHVBEC for 2.5 amps and not for applications where the servos will see >80 oz/in loads. Most 10s planes/helis are going to see peak loads substantially higher than 2.5 amps and 80 oz/in. Servos like 8411, 8417, 8611A, etc can easily hit 1.5 amps each. I've got some 8717s in a 65" 3D plane that are spiking around 2.5 amps each (servos commonly used in bigger 3D helis). Dimension does note 2 VHVBECs can be used in parallel to provide additional current....or you could use a Castle BEC PRO which will handle 20 amps on 10S input.
Regards,
Dave Lockhart
Team Castle Creations
NY
Dave,
Unfortunately Castle has an enormous warning:
Can you ask why this is?
Also . . . and bear in mind this is asked with all deference to your knowledge and experience, but I have tested my servos and never found more than a few mA of use at max. I generally land and find that I put 60 to 80 mAh back into my receiver packs. Are you certain that some servos hit multiple amps input in normal F3A sequence use? Also if such a limit for the BEC were hit momentarily I wonder if the Lipo would pick up the slack.
Joe
NOTE: CC BEC Pro should never be operated in series or parallel with another BEC or backup receiver pack connected to the RX/Servo side of the circuit.
TOP
TOP
Joe
My Feedback: (8)
Joe,
Here is a thread about servo specs and power consumption, along with a data sheet/analysis. I think this will answer some questions about how much energy is used by a servo during a sequence:
[link=http://www.rcuniverse.com/forum/m_8189267/tm.htm]Servo Requirement Thread[/link]
[link=http://www.ofremmi.info/F3A/Technic/Flight_testing/servo_flight.htm]Analysis[/link]
Joe P,
My goof....you are correct that the Castle BECs are not designed to be run in parallel, my intent was to point out that higher amp capacity high voltage BECs existed. Someone like Ed Alt or Jim Oddino could probably be more specific as to why the Castle BECs should not be run in parallel, but apparently this is a potential problem with some switching type BECs, but it is not a problem with linear type BECs (such as the ones produced by Tech Aero).
I agree that anywhere between 40 and 80 mah per flight is about right for electrics in pattern. So far as peak loads.....put an ammeter inline and lean on the servo arm....1.5 amps is easy enough to achieve, but maybe this does not happen in the air (as Ola's data indicates). I know years ago, I moved away from 100 oz/in servos on the rudder to the 8411 or 8611A because the added torque flew the plane much better (no so consistent with Ola's data) - so my presumption was the torque needed at the surface was higher than what the weaker servos were capable of providing. I'd also note that the speed of a servo is generally measured with no load (static), which has little to do with speed of the servo under load (in flight). There has been some interesting data posted on Run Ryder about this - some servos are dramatically slower under even small loads.
There are certainly a variety of ways to power the RX and servos. I'm quite happy with the parallel Tech Aero linear Vregs and dual lipos....8 flights easy for 3 oz with 100% redundancy and interchangeability (is that a word) with all the parts.....and easy to move from plane to plane in a pinch.
Regards,
Dave
Regards,
Dave
My Feedback: (42)
NJ
It could be that the BEC circuits can't handle another voltage source that might be at a higher potential than it is running at, i.e., maybe they don't have reverse current protection. If that's the case, then don't try this. Even so, if configured with the linear regulator around 0.2V lower than the BEC, while the BEC is operating normally it would not know of the presence of the backup linear regulator. The backup contributes nothing while this condition is true. It would also draw nothing from the receiver bus while the BEC is operating normally.
Once the BEC fails or dips below a certain point, the output from the backup regulator is immediate. At that moment, if the BEC can't handle another voltage source trying to hold up the receiver bus, then something may flow in reverse to it. If that's the case, don't try this. It would be disappointing to learn that a shortcut in BEC design would preclude a common sense solution like this.
Jim
NY
. . . . if the BEC can't handle another voltage source trying to hold up the receiver bus, then something may flow in reverse to it. If that's the case, don't try this. It would be disappointing to learn that a shortcut in BEC design would preclude a common sense solution like this.
Dear Sir,
I fly 2M F3A airplanes and am interested in creating a redundant power system for the RX by paralleling a VHVBEC with a Lipo attached to a linear voltage regulator set .2V below the VHVBEC. If the BEC lost power would it be possible for current to flow through the VHVBEC?
Thanks for making such great products!
Joe Peck
Subject: Re: Customer support
Date: February 9, 2010 2:59:09 PM EST
To: [email protected]
Hello Joe,
I sent a copy of your question to one of our engineers and here's what I got back,
"yes... Add a schottky diode in series with the output of the VHVBEC before
the other regulator."
Regards,
Alex
Joe Peck
Hello Joe,
Regards,
Alex
Ed or Jim,
If you're still listening in . . .
So looks like the VHVBEC does not contain a blocking diode, but I was thinking if the BEC lost power it would have to be either a failure of the BEC in which case I'm no longer concerned about hurting the BEC 'cuz its dead or a removal of 10S battery power. One could accidentally plug in the RX battery before plugging in the BEC fairly easily so I would expect that situation to arise often, but then wouldn't that mean the other end of the circuit is open, and if the circuit is open then no current can flow? I suppose I could do a $40 test and put a RX battery on the output end of the BEC and see if any magic smoke comes out , but I'm hopin' you guys can help me out here.
And, then back to the first discussion . . .
. . . so now if I put a diode in line with the BEC output won't that drop the voltage perhaps even enough to trigger the Lipo on a regulator to take over?
And Ed,
Is this a potential build project that would have any interest to you? I certainly would be happy to help finance the prototype production
Anyways, thanks for all the help as always!
Joe
[link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2682&P=FR]Tower Hobbies Schottky Diode[/link]
My Feedback: (42)
NJ
NY
Ed,
Wow . . . now don't I feel silly. I just realized you are Tech-Aero. Somehow I was under the impression that Ed Alt regulators were separate from Tech-Aero. Anyways now I get it.
But I wanted to clarify something . . .
The only component I'm really talking about here is the VHVBEC. I use a standard Jeti speed controller with no BEC. Normally I plug the VHVBEC directly into the RX battery port on one side and a 10S battery tap on the other side. This VHVBEC does not need to be connected to the speed controller other than the 10S tap. Forgive me if I am stating the obvious; I just wasn't certain from your last comment if I had been clear in how I was proposing to use this setup. So my dilemma is finding an independent UBEC that has a reverse flow blocking feature built in, and I would be happy to send you one these VHVBECs for dissection if that is of interest.
In either case thanks for the help, and look for my order later today
Joe
Joe
ORIGINAL: 2Sunny
Ed,
Joe
Ed,
Joe
Jim
I should have read this thread from the beginning. I looked up the specs on the VHVBEC and see it is designed for only 2.5 Amps. I don't believe that is adequate. Each servo will draw that much for a short time when starting or stopping and if you get five starting at once (in a snap) you won't get the desired torque unless the LiPo supplies the current.
They discuss parallel operation to overcome this short coming. so it should work from that standpoint. I was thinking it might be nice to add so I wouldn't have to charge my battery pack after each session. But it sounds like the LiPo would be supplying a lot of the current.
What they should and could build is a VHVBCC. The same device with an 8.4 volt regulated output could keep your 2 cell LiPo charged all the time.
Jim
Jim
NY
On principle I wholly agree that what I am doing to this poor little VHVBEC is pushing the limits and one would be better off putting 2 in parallel as suggested by the manufacturer. However, having said that I will add a couple quick points:
1) I flew several dozens flights of Intermediate Sequence with only the VHVBEC attached in November with no noticeable problems.
2) The graph below taken from the servo test report listed above by gaRCfield shows peaks of less than 1 amp for a P09 sequence.
3) Even if the VHVBEC couldn't supply the current needed for a moment I wonder if the regulated Lipo would simply pick up the slack for that brief second.
4) Paralleling 2 VHVBEC's really wouldn't be too horrible of a solution since they only weigh 17 g anyway.
Of course I am NOT suggesting others should duplicate my foolishness (at least not until I've demonstrated its efficacy and safety), but rather just "thinking out loud" as I experiment with this stuff.
and, I'm planning on testing the VHVBEC tonight by putting the regulated Lipo power to the output side. I figure it's all in the name of science and fun so "what the heck"
Anyways, thats it for now and thanks for all the great input, Jim! Keeps me thinking about what to work on next!
Joe
Joe
My Feedback: (42)
NJ
I think there is another solution...
I am running a Tech-Aero dual regulated system in both my BM-VF3's, one on a YS set-up and one EP (Pletty 30-10 EVO, Jetti 90 on 72 MHz). One of the smartest things I've added to my ships. I flew 40% IMAC planes for years and always used dual regulated set ups. I did'nt think it was all that important with the much smaller pattern ships (smaller less current bigger RX pack I'd be just fine), I was wrong! I had an older regulator that failed while sitting on the runway ready to take off, the plane went to idle with the fail safe, could have been a disaster.
Last year, I had a brand new 750 Lipo go bad in flight, but I was running 2 of them with the Tech-Aero dual regulator system,...If I had not been in the habbit of checking my batteries before each flight I would not have cought the problem,....Thanks ED for a great product and a GREAT piece of mind, other possible disaster avoided.
My two cents anyway,...That was a wake up call, that I was being to lax in day to to flight preparations. Not really relative to the Castle discussion. I just wanted to share that with you guys.
bholsten
Custom Airframes of America, Team Black Magic, Advantage Hobby, Guardian America, Dist. 2 FAI Champion 2009.
bholsten
