CA MODEL ONAS BUILD
#81
RE: CA MODEL ONAS BUILD
Hello Tuny.
Congratulation, very good job.
I am again in the "drugs" I am waiting an Onas ARC that bought from Antonio Rodriguez recently, I am planing to fly with it next November in Medellin, maybe it would be in my apartment next saturday......
Un abrazo.
Jorge Lozano
Un abrazo.
Jorge Lozano
#84
Bien Alejo, me considera un piloto de F3A en uso de buen retiro, pero de nuevo en esta "Droga".....
What is your impresión about the Onas fly? What equipment are you using? please let me know.
Best regards.
Stati Schengen
(Todavía conservo la credencial de Sauce Viejo) jajajaja
Best regards.
Stati Schengen
#85
STATI!!!! que bueno que regresas!!!! nos vemos en Medellin!!
About the SFG, the reason is simple, I dont like how the look (I'm not saying they dont work)
more....
more....
#91
Hi
This Delro Addiction is in fact covered with film ..pretty nice job to!
http://www.rcuniverse.com/forum/fb.asp?m=9651320
#93
Hello Tunny.
Yesterday I received my Onas ARC kit, I have a question, what is the diameter of the music wire that you use for the removable rudder ? I want to copy the idea.
Thank you.
Jorge.
Thank you.
Jorge.
#94
guille the fuse will be painted...
Jorge the wire is .047" (1.2mm), i use it with this hinges: http://www3.towerhobbies.com/cgi-bin...&I=LXD944&P=SM
Saludos!!!!
TUNY
Saludos!!!!
TUNY
#95
more..
preparing the fuse for painting.
-first I used finishing resin with a little microballoons to fill the balsa ruder post.
-then sanded all the fuse with 240 sandpaper, dry sanding.
-then added filler to all the fuselage mold joint and all other places where needed, this filler will be sanded most of it out
-then I will use white primer only where needed to get an even surface for painting
-then more filling-primer-sanding-etc until a perfect surface (this step only if needed)
#98
more...
sanded all the filler and applied the first coat of primer, I only use primer where needed because the fuselage is already white and a great surface for painting.
pics...
pics...
