YS 170DZ problem
Old 06-06-2010 | 01:53 PM
Default YS 170DZ problem
After 170 flights with absolutely no problems, I developed a problem of the engine quiting in flight, not abruptly just winding down to a stop. Feeling it was too rich, I had 2 turns out, I started at 1 and 1/2 and had good success through about 5 flights, now did it again and I've changed plug, move the needle out and back in, and the engine will start but can't keep the low in running and when I move it to high throttle it acts like it want to quit again. I thought about moving the pump screw but ain't got a clue which way or if that will help. Is it outside or inside the engine?
Old 06-06-2010 | 07:08 PM
My Feedback: (45)
Default RE: YS 170DZ problem
On new engines the backplate screws tend to loosen up and will give you the exact problem you are having. Pull the engine and retighten all the screws. Once you tighten them again they will stay tight, but I would bet you have an air leak somewhere,
Arch
Old 06-07-2010 | 12:01 AM
My Feedback: (42)
ORIGINAL: rcpattern
Arch
I just went through this exact scenario and it turned out to be 3 of 4 backplate screws were loose. The gasket was wet under the area where it should be sealed 3/4 of the way around. I suggest using some locktite on the bolts when reinstalling. Everythingis now A-OK after tightening it all up. Thanks to Ken Velez for helping me with getting everything torn down & back together while I was on the road to get this done too!
Old 06-26-2010 | 10:31 AM
ORIGINAL: n1369e
Old 06-26-2010 | 10:42 AM
Thanks gentlemen for your quick responses. I have sent the motor to us service
and was told the crank shaft is bent by .8000. A new crank was installed January of 09.
Motor has not been in a crash. All results not known yet. Will post when known.
Old 06-26-2010 | 11:04 AM
My Feedback: (7)
Same problem with me and it turned out that I had head screws that needed to be tightened. thanks Richard Verano
Greg Grigsby
Old 07-22-2010 | 07:28 AM
Received the engine back from service in Arizona. Richard told me the crank was bent, the bearings were shot, the piston ring needed replacing. He did me right and charged no labor, and only for some of the parts. I figured about 25% for what could have been. He certainly helped me out.
Old 07-22-2010 | 08:45 AM
Just curious.... Would that be normal wear for a 1.70 DZ with that amount of time on it?
Old 07-22-2010 | 09:29 AM
Mike
A bent crank is never a "normal" wear and tear!
Dick
Old 07-22-2010 | 11:04 AM
Well... I sort of thought that but having never owned one of the larger Y.S. mills I didn't know.
Old 07-23-2010 | 04:05 AM
Here's normal wear and tear... Rear bearing in a brand new DZ170cdi with about 50 flights on it (15% nitro, 20% oil).
You can see the bits floating in the puddle of oil.....
Old 07-24-2010 | 07:12 PM
I don't want to say too much but, you might be better off stopping your tear down at this point, packaging it up and sending this particular YS motor to Richard at Performance Specialties. It appears the ball bearing shield of the rear bearing in the above photo has disintegrated. I ran these motors for years and had similiar problems. Back then, I tried everything that was suggested. Based on your opening statement in this thread and the problems you and others have had, this is probably not a fluke! Thanks__Everette
Old 07-24-2010 | 08:23 PM
You sound bored there TN Walker,
I don`t remember you running a YS since the 120 days,
In fact I haven't even see you flying at a contest in five or six years. back then I recall you using 2 strokes
have you even seen a 170
Bryan
Old 07-25-2010 | 03:30 PM
I would say that is not normal for 50 flights on the 170 dz. I've been running them Dz's for the past 5 years and haven't seen that after only 50 flights. Warranty should be able to take care of this. But thats not my call. I generally get 12 to 15 cases fuel before i replace the bearings and ring to avoid such a failure .
gary
Old 07-25-2010 | 11:02 PM
I've just fired off an e-mail to whom I bought the engine with some pics and I'll see what will happen.
I probably should have just pulled the engine and sent it back but I live in Australia and I bought it overseas. Now I've stripped the motor I don't really expect any support, a new rear bearing posted free of charge would be the best I could hope for as I certainly won't be posting them a box full of motor bits. Given how well the engine is sealed up I'm surprised how the oil manages to work itself around to all the bits...
Old 07-26-2010 | 05:23 AM
if warranty is not granted. Clean the motor with dish soap and a tooth brush being sure to dry it before oxidation sets in on the metal and install the new bearings using a zip wire tie to squeeze the crank ring while pushing the crank in the final bearing seat. it takes a bit of patience but its not that difficult.
gary
Old 07-26-2010 | 04:41 PM
Thanks Gary, I just pulled the bearing apart last night and I found the inner race damaged in a local area. I have only ever had one bearing with this type of race damage and it was a stainless/ceramic hybrid front bearing used in my Hanno but as I hand start that I caught it early before it fell apart. I replaced it with a new OS part and it's still going strong..
ID:	1473829   Click image for larger version
Old 07-26-2010 | 05:49 PM
I'm no rocket scientist but that looks like a metallurgy issue. Not necessarily a ys quality problem more of a bearing supplier issue. But I hope they will warranty it either way.
gary
Old 07-26-2010 | 07:05 PM
Yeah, I'd say the same, looks like porosity, it may have been just under the ground surface, or juuust poking through, but after a few thousand balls have run over it, it may have chosen to part company.
Old 07-26-2010 | 11:46 PM
Good News!!,
word from YS is they'll fix it under warranty so it looks like I will be shipping a box of bits to Japan.
Interesting, they suggested I try the new APC 20x10.5 prop when I get it back.
Google doesn't seem to know much about this prop???
Old 07-26-2010 | 11:53 PM
ORIGINAL: bjr_93tz
Good News!!,
I have just started using this prop about a month ago on my cdi with CP 20% fuel, it's turning about 7,000 on the ground, but you'll have more than enough power for the verticals. Down line is nice & slow.
You can order from Central Hobbies or direct from APC.
Adrian
