YS 120
Old 07-14-2010 | 06:12 PM
Default YS 120
My YS120 engine does not idle well. The RPM will remain high (4000) for a few seconds then drop to 2500 for a couple seconds and jump back up. It does this cycle a few times then dies.
Old 07-14-2010 | 06:16 PM
Default RE: YS 120
air leak-gaskets needle o-ring etc
gary
Old 07-14-2010 | 07:59 PM
Default RE: YS 120
Lightly wet sand the contact surface of the valve cover, sometimes it has a high spot that cause the leaking. Otherwise, check for hair line splits on all fuel & vent lines.
Adrian
Old 07-15-2010 | 09:10 AM
Default RE: YS 120
If its a 120AC the o rings on the air chamber need replaced about every 200 flights.
Jim
Old 07-16-2010 | 05:30 PM
Default RE: YS 120
I'd like to add that it runs ok with the glow plug battery attached
Old 07-16-2010 | 07:51 PM
Default RE: YS 120
i'm sure you changed the glow plug? ys#4 os -f
gary
