12fg futaba
Does the throttle trim have to be programed in, when ever I move the throttle trim all the way up or all the way down the servo doesnt move
RE: 12fg futaba
No, trim is on automatically.
A few suggestions.... 1. Are the throttle and elev trims 'crosssed'? ie is the trim lever you are using assigned to throttle? I think the default on the 12FG is to have the trim lever left of the elev stick is throttle trim and vice versa. So, check the trim lever next to the elev to see if that works. The trims are assignable so you can switch the trim to where ever you want it. 2. Is the trim rate turned way down? On the 12FG, you can program the rate step the trim lever will have so you can have very coarse to very fine trim adjustments. If you have the rate turned way down (fine) it is hard to tell the servo is moving when you change the trim. Woodie Team Acme LG Team 3M Blenderm |
RE: 12fg futaba
Go under the function menu and make sure the throttle trim is assigned to the correct trim lever or slider that you want,
Arch |
RE: 12fg futaba
ok thanks will do that thanks for the help guys the manual is alittle vague
RE: 12fg futaba
I think by default the throttle trim only works when the stick is in the lower half, i.e. 0-50% throttle, maybe even 0-25%. Throttle trim is only useful when adjusting idle, I think that's the idea behind the feature. If you've programmed throttle cut, make sure it's off. Throttle cut overrides both stick and trim levers.
RE: 12fg futaba
Man, I'm glad that someone ask that question. I had the 9CAP,10C and now a 12FG, I'm trying to move the throttle trim to the slider, and the manuel is not
very clear. I'm looking to move the throttle trim, over to the slider to start and stop the motor, thanks for the help guys |
RE: 12fg futaba
Jarvis,
Just go under the function menu and choose the left slider for the trim. You can set the % of how much it works and such. It wont work until below half throttle. Works great that is how I set up all my glow stuff, Arch |
RE: 12fg futaba
Arch
Thanks alot, got it to work now how, do I get it to work on my 10C. could not find anything in to manual. |
RE: 12fg futaba
Jarvis,
That takes some playing. Somewhere someone had an article about doing it on the 9C. It works the same way. I'll try to find that link. I did it on my dad's 9C, but it wasnt easy. Arch |
| All times are GMT -8. The time now is 12:06 PM. |
