RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Help to ID this airplane (https://www.rcuniverse.com/forum/rc-pattern-flying-101/11058231-help-id-airplane.html)
kitfox1 04-26-2012 03:46 PM
1 Attachment(s)
I need your help to ID this airplane. I also would like to know if you have the manual what is the CG location and control deflections. Thank you for the help.
RC_Pattern_Flyer 04-26-2012 03:51 PM
RE: Help to ID this airplane
Thats the fliton element.
Safe to start cg at the front of the wing tube
Chuck
kitfox1 04-26-2012 04:10 PM
This airplane has a one piece wing. Do you have the measurement from the wing leading edge to the wing (front edge) tube. Thank you for the help.
RC_Pattern_Flyer 04-26-2012 04:45 PM
Use 25% of the mac.
Chuck
wildwillie3 04-27-2012 03:00 AM
kitfox1,
I have some of the manual pages at home. It has the recommended throws and recommended CG location. I will scan them and send them to you this weekend.
Bill
kitfox1 04-27-2012 05:30 PM
Thank you. The settings from the manual will give me a good start. This is my first 2 meter airplane and I am installing a YS 160 engine with JR equipment all around. Thanks again for the help.
lodomjr 04-28-2012 07:51 AM
kitfox1,
Just from looking at the photos in your post the prop on that engine looks like a prop for an electric motor. If it is you don't want to run that engine with that type of prop. For a YS160DZ I would suggest a APC 18.1 x 10 pattern prop and there are other choices also that will work.
Larry
wildwillie3 04-30-2012 02:59 AM
1 Attachment(s)
Here are the sheets that I have.
wildwillie3 04-30-2012 03:01 AM
1 Attachment(s)
some more,
kitfox1 04-30-2012 10:44 AM
wildwillie3,
Thank you very much for the manual.
