RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Ys175 to 185 (https://www.rcuniverse.com/forum/rc-pattern-flying-101/11589686-ys175-185-a.html)
Torben Parsberg 11-09-2013 04:53 AM
Ys175 to 185
hey some who can tell me what improvements have been made on ys 185 versus 175've seen picture of No tube,,front of the pump, what's done inside the pump? What prop do it run With . Want to see pic ,,:):cool:
rm 11-09-2013 03:14 PM
Yeah, I'd like to hear what the guys running this motor think of it. Hard to believe they can improve on the 175. Mine's been the most reliable and pleasurable YS motor I've ever run.
apereira 11-09-2013 06:03 PM
Comparable power from the 160 to the 170, the pump reference has been removed, have not dissasemble the pump yet, as there is no need to. The engine is still identical to the 175 but the pump reference hose, the ignition is half the size, and it seems to have an output for a tachometer, but I have no instructions. It should go well with a 21, 20.5 x 10 is ok but not enough prop.
rm 11-10-2013 04:12 AM
Any chance the new ignition can be used with higher voltages so we won't need a reg on it?
Ryan Smith 11-10-2013 09:58 PM
What are the preferred propellers for the 175 (and now 185)? It seems that APC is still the preferred propeller, however based on a conversation I had with Mike Harrison at the Nats this year, the big drawback on the APC is weight. Are there any Falcon or Mejzlik propellers that will provide enough performance without the weight penalty? I'd love to see a four-bladed prop appropriately sized for the larger YSs (bonus points if it's carbon fiber) as I always preferred the feeling of the airplane with a four-blade prop, over several designs and from the 140 to the 170.
riot3d 11-10-2013 10:28 PM
I've been using the 20.5x10 PN on my 175 from day 1.
Adrian
UKpatternflyer 11-11-2013 02:31 AM
I've used 20 x 10.5PN, 20.5 x 10PN and the 21 x 10WPN props and I prefer the 20 x 10.5PN. This weighs in at 157g as oppsed to 173g for the other two props and gives a very good speed range for all weathers. I've tried using both 20 x 10 and 21 x 10 Mejzlik props and are much lighter (21 x 10 was 135g). However the noise was unacceptable, my understanding being the power pulse from the 4 stroke exciting the very undamped structure of the carbon propeller giving a horrible in-flight tone. Hence I went back to APC; other than the weight, they're ideal.
Might be worth borrowing a carbon prop to see how you find them rather than shelling out a lot of money for them just to be dissapointed?
Keith
rm 11-11-2013 03:28 AM
I ran the 21x10 all summer. I really liked the pace (6300rpm) all around for the simpler maneuvers in the masters class. Doubt fai would like it. Been trying the 20.5x10 lately and am going to switch to it as it pulls over the top better then the 21 and pace seems to be about the same. A 21x10 at 6300 is getting close to electric numbers, just doesn't quite have the torque of electric. 185 may be perfect for it.
Weights of the apc's are at 6.1oz for the 20.5 and 21 x 10. 20x10 is 6.5oz, it's a narrower blade but a lot bigger hub.
Torben Parsberg 11-11-2013 09:35 AM
hey delro have a 3 blade fore 35 50ccm maby??
http://www.delro.de/modell_info.php?kat_id=5&mod_id=22
tuny 11-11-2013 04:06 PM
I'm using 20,5 x 10 on my 185. It could use a bigger prop. Runs great. More torque and more power than 175. And the CDI is HV
Freddy 11-11-2013 07:21 PM
I have a more basic question. Are there any distinct advantages between the YS175 over the YS170? I am thinking about getting a 175 but maybe a 170 is just good enough for the FAI schedule. I currently use a 170 and am very happy with it and thought about getting a second one.
tuny 11-11-2013 08:29 PM
Freddy in my oppinion the 170 is a great powerplant. Enough for FAI. 175 and 185 are beasts
riot3d 11-11-2013 08:42 PM
The 170 has not been available commercially for quite a while now. Of course, you can still get used ones.
The main advantages between the two are better mid range torque, able to swing a 20.5x10 PN prop with authority for better transition, enabling a slower down line & more constant speed.
There is absolutely nothing wrong with the 170, it has enough power to pull any of the designs out there. However, if you're flying those newer design with the more forward larger canopy/ taller fuse type or the bipes, the 175 will definitely gives you an advantage. Especially, the power hungry F-15.
Adrian
Dave Harmon 11-12-2013 07:48 PM
I finally had to give up on my 170dz.....the only thing that didnt break was the moving parts.
Mainly....the pump was/is a giant problem.....I might like to try the Sport version though....got lotsa fuel left.
Angus Balfour 11-13-2013 09:10 AM
I'm still using a 170 that is about four, maybe even five years old. It is only now just starting to develop some problems. The injector came out of the cylinder head and broke off the hypodermic needle on Sunday. The main bearing is also shot to bits. Apart from that, no problems and this will be its first service.
Would love to try the 185 :)
MTK 11-14-2013 09:28 AM
There's a 21 x 10 std blade width that should work super on the 185. Problem is the weight at around 200 grams. What it probably needs is a 3 bladed woodie at around 19x10. But you;d have to make your own....have not found a commercially available product and I've looked quite a bit
apereira 11-14-2013 01:20 PM
A prop designed for the 185 should come out soon from APC, they have been doing this for years, don't this case will be different, just need to wait.
drac1 11-16-2013 04:21 AM
The injector coming out is not a knew problem. a couple of my 160's did this, but my 170's and 175's have been OK.
YS repaired my 160's under warranty well after the warranty period had expired.
drac1 11-16-2013 04:30 AM
I'm running the APC 20.5 X 10PN on the 175's. Around 7000rpm and the downline braking is good. Pulls through FAI easily.
I have 2 x 185's on order and last info was they should arrive late November.
I agree with Apereira. APC will have a 185 prop out soon. Hopefully a 3 blade.
