Skyline. 2m F3a Bipe
Some pics of the early stages of my new build. Based on my last monoplane, but with 2 wings. https://cimg6.ibsrv.net/gimg/www.rcu...dc28668f70.jpg
https://cimg8.ibsrv.net/gimg/www.rcu...6abce2dd8e.jpg https://cimg6.ibsrv.net/gimg/www.rcu...0e3843eedb.jpg https://cimg1.ibsrv.net/gimg/www.rcu...47ff03af89.jpg |
Very impressive! The structure looks quite light weight. Did you do your own laser cutting or outsource it?
No i draw it then send it to Belair (uk) to have it cut. Would love a laser cutter but money and space wont allow 😀
Getting on with sheeting now, done the easy bit. Just got to deal with the planking. https://cimg0.ibsrv.net/gimg/www.rcu...63c585cf1b.jpg https://cimg3.ibsrv.net/gimg/www.rcu...cb434ee692.jpg https://cimg6.ibsrv.net/gimg/www.rcu...04fbeaf829.jpg |
Very nice work. What thickness sheeting for the fuse...same for wings/stabs?
-mark |
Thanks Mark. 3/32 all round on this, not gone for contest grade this time, for cost reasons. These sheets are coming out about 21g for a 36"x4" sheet.
Couple of pics of the motor mounting. I've designed in a shroud to try and help with cooling. I know these motors can run a bit warm!!https://cimg8.ibsrv.net/gimg/www.rcu...b0de18121b.jpg https://cimg9.ibsrv.net/gimg/www.rcu...cee58127df.jpg |
Very impressive work. Was just getting a reply from flywilly regarding his results with the Myvec files and he sent me this link. I've been on the fence about the Neo Stage Bipe for a month or two. Any interest in offering files for this one? Thanks, Ted.
Finally finished planking the top/front of the fuz and managed to release the canopy. Pretty pleased with how it came outhttps://cimg5.ibsrv.net/gimg/www.rcu...a8e3887028.jpg
https://cimg5.ibsrv.net/gimg/www.rcu...a708b11e15.jpg https://cimg9.ibsrv.net/gimg/www.rcu...9bb87b8688.jpg |
Nice work, much appreciated!
Great work so far.
Just beautiful, great work Dan !
Thanks Guys. Alex, if i got to half of your building skills, i'd be very happy!
Good golly Mrs. Molly! That is some fine looking workmanship!
The form looks pretty rockin too! |
It's a shame to cover up that intricate structure. Need to figure a way to sheet it in clear! Very impressive details.
Wow! All I can say is just...wow!
Fuselage is pretty much complete now. Just the rudder to cut out and face.
Planking the bottom of the nose was very time consuming, each piece had to be shaped and soaked to bend up to the nose ring. Also aliphatic meant only 2 strips at once. Worth it though, even with a rough sand its come up nice. Happy with weight, its 880g at the moment with the canopy, so prob be about 900 when its cut out and hinged. So its about 20g lighter than the old one, without using contest grade balsahttps://cimg6.ibsrv.net/gimg/www.rcu...43eb61fd72.jpg https://cimg1.ibsrv.net/gimg/www.rcu...6f7ca37a1f.jpg https://cimg3.ibsrv.net/gimg/www.rcu...672eed1123.jpg https://cimg2.ibsrv.net/gimg/www.rcu...dec3831d8c.jpg |
Nice work. BTW, should I send my shipping crate to you this week or next? Be sure to pack it carefully for the trip across the pond. It's awesome that you've offered it to me...…..LOL. Keep up the good work, Ted.
So the airframe is pretty much ready to cover now, hoped to have had it flying for the next comp but that seems unlikely now. Small things like checking the wings are square seem to take ages, especially when you cant put it together easily in your shed! Cutting ailerons out was also a pain, mainly because theres 4.
Not too many pics of the wings, but heres the ones i took. https://cimg8.ibsrv.net/gimg/www.rcu...ebd2bc7ffa.jpg https://cimg9.ibsrv.net/gimg/www.rcu...54e1db9161.jpg https://cimg0.ibsrv.net/gimg/www.rcu...c747f851a1.jpg |
https://cimg1.ibsrv.net/gimg/www.rcu...7ac2c75723.jpg
https://cimg2.ibsrv.net/gimg/www.rcu...030cca9daa.jpg https://cimg5.ibsrv.net/gimg/www.rcu...306a3380ab.jpg The wing structure was glued to the bottom sheeting as a whole, then each half had the top sheeting glued on seperatley. I used a jig top and bottom, weighed down, which i've done with all my wings. As long as the bench is flat, so should the wing. |
Tail is very basic when there's no elevator or servohttps://cimg6.ibsrv.net/gimg/www.rcu...c5d88252bf.jpg
So this is where its at at the moment, bar the ailerons and rudder being cut outhttps://cimg7.ibsrv.net/gimg/www.rcu...90213c5251.jpg
https://cimg6.ibsrv.net/gimg/www.rcu...c440a02b9a.jpg https://cimg5.ibsrv.net/gimg/www.rcu...b029fd85cb.jpg |
Realy nice looking. What is the engine trust angle?
So it been built with 2.5° right thrust and 0 down thrust. I trim my models out gravity neutral so i expect the down thrust will only need a little tweaking to hold a vertical up line.
Right thrust was just a guess really and may need moving a lot, it might not. Dan |
Got it finished and flying this weekend. Had 4 flights with it yesterday, even managed a p19 with it on the last flight.
Very pleased with it so far, bit of work to do with it re rudder trim but apart from that its great. As with most biplanes, rudder is very powerful making rollers and ke manoeuvres a lot more stable and easier to control. Problem is the powerful rudder control it amplifies any unwanted yaw trim. It was very calm aswell so will be interesting to see how it performs in the wind. https://cimg6.ibsrv.net/gimg/www.rcu...f5b733ff90.jpg https://cimg6.ibsrv.net/gimg/www.rcu...39e0bb0512.jpg https://cimg9.ibsrv.net/gimg/www.rcu...51dc5de5e9.jpg https://cimg8.ibsrv.net/gimg/www.rcu...730a7ff643.jpg |
Congratulations! The color combinations you chose are simple and stunning. I have really enjoyed following your build and wish you continued success.
Hello Dan
Awesome job ! " Problem is the powerful rudder control it amplifies any unwanted yaw trim. " We have the same with bip Arpege. So we add a little plate at the trailing edge of rudder. It works fine. Claudehttps://cimg3.ibsrv.net/gimg/www.rcu...5107951d5a.jpg . https://cimg9.ibsrv.net/gimg/www.rcu...c1f5fa546e.jpg |
Congratulations for the first flights Dan, awesome model !
I hope you will have great results with it in competitions ! |
Love the color scheme!! Simple and visible. Check out the 3rd photo from the bottom here: Ascent ƒAƒZƒ“ƒg
The 'fat' rudder trailing edge really works. Excessive rudder authority is a bit of a problem with the modern pattern design. The Skyline looks great and as Alex said above; good luck in the comps!! |
Thanks guys. I will definately have a go at modifying the rudder. Still early days with it but im happy so far!
Great result, congrats on the build. Now that more time has elapsed, two things I'm curious about....first, did you find that your initial 2.5 deg right thrust proved good and second, from my view, your flying stab servo layout is unique...are you still pleased with that result in terms of holding trim, flight characteristics, and servo power [BTW, what servo did you use in that position]? Thanks, Ted.
