RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Thunder Tiger 120 Pro question. (https://www.rcuniverse.com/forum/rc-pattern-flying-101/1645377-thunder-tiger-120-pro-question.html)
Hans Meij 11-27-2004 04:07 PM
RE: Thunder Tiger 120 Pro question.
Very cheap in the UK: 69 pounds
http://www.sussex-model-centre.co.uk...Engine-940.htm
Schpankme 11-27-2004 11:21 PM
1 Attachment(s)
Swill,
Your engines RPM number indicate the optimum prop to be an APC 16.5x11 (APC 16.5x12 -> repitched to 11). Another consideration would be an APC 17x10N, the prop chart shows it to be at the high end of the load, but still capable of 8400 rpm.
_________
Schpankme
Gregor Giliams 12-25-2004 09:46 AM
Got verry verry broad needle.
Seems to be my problem as well.
How much should i cut off the header..,
got mine for 155 pounds. thats for engine, header and tune pipe :)
Runing it with a 15 -12 at the moment doing 8400 rpm but it can do more because it was not on idle verry well [&o]
Schpankme 01-03-2005 11:48 PM
1 Attachment(s)
Thunder Tiger PRO-120-RP
Thunder Tiger 'original" Tuned Pipe + 40mm (1.6")
Nitro 10%
Synth Oil 15%
APC 17x12N @ 7900rpm
__________
Schpankme
Obed 01-07-2005 08:12 PM
Thanks for all the good info. How long is your total assembly length, measured from your glow plug to the end of your pipe?
DWH
Xrod 01-07-2005 08:19 PM
Test ran my new engine with a MA 16x10 with straight header, no pipe and was turning 9030 rpm. Plan to be using an APC 16x11. Had some problems with middle range being rich, but will wait till I have the pipe on before I start tweaking the pump.
nubli 07-02-2008 02:52 PM
I will be using mufler tuned pipe for os 90.. will it be enough? that's the only pipe I have, and I like to start the engine in two days.. need to run it -in before practicing f3A leo 110
thanks in advance for your answers guys
nubli
