RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   prop for tai-ji 60 (https://www.rcuniverse.com/forum/rc-pattern-flying-101/2345546-prop-tai-ji-60-a.html)
noam_h 11-15-2004 04:39 AM
prop for tai-ji 60
Which prop do you recommend for tai-ji 60?
The engine will be MVVS 91, probably with long tune-pipe.
jetmech43 11-15-2004 11:35 AM
RE: prop for tai-ji 60
I would try a 14-8 pattern prop and then go from there
tommy s 11-15-2004 12:03 PM
The MVVS engines have a lot of low end grunt and will pull a lot of prop. Ran
a 13x10 pattern APC with a MVVS .77 so the .91 will probably pull a 14x10
at least.
tommy s
Schpankme 11-15-2004 07:29 PM
1 Attachment(s)
If you use the MVVS tuned pipe for the .91:
APC 15x10 @ 8200 rpm
APC 15x11 @ 8000 rpm
_________
Schpankme
Scoubidou 11-15-2004 09:52 PM
Schpankme
What software are you using to shows the RPM -prop below?
Schpankme 11-15-2004 10:21 PM
1 Attachment(s)
Scoubi,
Utilizing a "known" value (prop load & rpm) for an engine rpm and prop combo, you can use ThurstHp to evaluate different prop sizes by adjusting the RPM until the HP equals the Prop being compared. - see example
_________
Schpankme
